Best Multi Vendor Marketplace Plugin for WordPress › Forums › Product Vendors › Update vendor products approval
- This topic has 19 replies, 2 voices, and was last updated 6 years, 3 months ago by
- November 19, 2019 at 2:29 pm #92934
jorsenmejia
Participanthow can I make my vendor product listing to approve by the admin when the users update the list?
- November 19, 2019 at 2:52 pm #92936
jorsenmejia
Participantwhere can I locate the table name of fields for booking of products?
- November 22, 2019 at 8:22 am #93369
jorsenmejia
Participantplease need answer
- November 23, 2019 at 10:35 am #93546
– Please set OFF “Publish Product” option form WCFM Capability setting. If you are using WCFM – Group then do this at group level capability as well.where can I locate the table name of fields for booking of products?
– Sorry, don’t get this. All product data store in “postmeta” table.Thank Y
- November 23, 2019 at 11:21 am #93565
jorsenmejia
ParticipantI have an issue when I update the products, the product content that I change after I publish it when I checked the product page it’s already updated even though the updated product is not yet approved by the admin.
- November 23, 2019 at 11:24 am #93569
jorsenmejia
Participantone thing how can I make the short description and description to normal text area only?
- November 26, 2019 at 11:29 am #93994
jorsenmejia
Participantany update ?!
- November 26, 2019 at 12:50 pm #93998
jorsenmejia
Participanthow to filter the products by place in-store page? using shortcode? or custom code?
- November 26, 2019 at 12:59 pm #93999
jorsenmejia
Participant$store_address = $store_user->get_address_string();
I tried this code but it didn’t work <?php echo $store_address; ?>
- November 26, 2019 at 2:35 pm #94020
jorsenmejia
ParticipantHow can we insert product data into the database using rest API?
endpoint URL using rest API? - November 26, 2019 at 2:45 pm #94023
– Please set OFF “Rich Editor” from WCFM Capability setting – https://ibb.co/GC52f8m
If you are using WCFM – Group then do this at group level capability as well.how to filter the products by place in-store page? using shortcode? or custom code?
– Why you are not enable GEO search for this page from WCFM Admin Setting -> GEO Location – https://ibb.co/YNGNtwrThank You
- November 27, 2019 at 12:44 pm #94214
jorsenmejia
ParticipantHi. How can I set my add new products input fields to required fields?
- December 4, 2019 at 5:58 am #95956
jorsenmejia
Participantany answer
- December 4, 2019 at 8:50 am #95965
jorsenmejia
Participantupdate please
- December 4, 2019 at 8:52 am #95967
jorsenmejia
Participantone thing where can I edit the template (path only) https://gigant.com.ph/professional-manager/products/
- December 7, 2019 at 1:08 pm #96416
– Which fields? Already there has an option for this at WCFM Admin Setting -> Product Custom Validation – https://ibb.co/Mg9ZJxX
- December 18, 2019 at 8:22 am #97859
jorsenmejia
Participanthow to set my edit products to confirm by admin when user edit the content?
- December 18, 2019 at 8:29 am #97860
jorsenmejia
ParticipantI tried this one
– Please set OFF “Publish Product” option form WCFM Capability setting. If you are using WCFM – Group then do this at group level capability as well.but when I check it to store page the products already updated even though is not approve by the admin
- December 18, 2019 at 8:34 am #97861
jorsenmejia
Participantnvm this post it’s working thanks
- December 23, 2019 at 5:32 pm #98715
MemberThanks for the update!
- The topic ‘Update vendor products approval’ is closed to new replies.
