Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Feature Request › URGENT HELP
- This topic has 8 replies, 3 voices, and was last updated 7 years, 4 months ago by
- October 23, 2018 at 2:37 pm #34652
nenad.stamboliski
ParticipantHello
I want to replace the home menu with a welcoming page where I will explain all the functions in the control panel to the sellers and the current home page to be under another name ….– how do I change jQuery for categories style?
-to first select the main category and after select a subcategory of that category?
You can see the link below.https://jquery-plugins.net/dependent-dropdown-jquery-plugin-for-cascading-dropdownlist
- October 24, 2018 at 4:24 pm #34774
Are we talking about this on FB before?
1. I want to replace the home menu with a welcoming page where I will explain all the functions in the control panel to the sellers and the current home page to be under another name ….
– I will check this and know you2. how do I change jQuery for categories style?
– How many sub-category labels you have?Thank You
- October 25, 2018 at 5:32 am #34908
Neno
Guest1. I think i solve this i go in plugins/ root and there is view … and i change welcome dashboard and now looks perfect ..
2. i have around 50000 Category and subcategory also this three go to 5th subcategoryCategory
– Subcategory_1
– Subcategory_2
– Subcategory_3
– Subcategory_4
– Subcategory_5 - October 25, 2018 at 6:15 am #34909
Neno
GuestThis reply has been marked as private. - October 25, 2018 at 7:31 am #34918
1. That’s great.
2. So you have category upto 6th hierarchy level? We can do this fro you but this will be a custom development.
- October 25, 2018 at 11:43 am #34946
Neno
GuestYes Pls help me with category coz I w8 3-4 days to solve this problem and site need to go live Thanks
And with a new update, all that I change in plugin go rewrite on my code is there some solution to put this when I make an update to stay saved?
- October 25, 2018 at 5:04 pm #34975
Category change will cost you @125 USD
Do not edit ant core files, do any customization from child theme’s functions.php using Hook and Filter.
- October 26, 2018 at 6:59 am #35030
Neno
GuestThis reply has been marked as private. - October 26, 2018 at 7:53 am #35037
Can you please communicate on this with me here – https://wclovers.com/woocommerce-multivendor-customization/
- The topic ‘URGENT HELP’ is closed to new replies.
