Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Vendors › Urgent: problem with the commercial manager
- This topic has 7 replies, 2 voices, and was last updated 7 years, 2 months ago by
- June 26, 2018 at 11:41 pm #25515
javier
ParticipantHello friends, the problem is that the button that is to edit the products disappeared. Attached image
- June 26, 2018 at 11:43 pm #25517
javier
Participantfrom the administrator if they appear, but from the seller not
- June 27, 2018 at 6:55 am #25526
You are using Dokan multi-vendor, right?
Kindly heck under vendor user profile from wp-admin -> users.
Dokan has a setting option there -> Add product
I think it’s not enable for this vendor user.
Actually, WCfM does not consider this setting option before last update.
Enable that and it will resolve for you.
- June 27, 2018 at 7:45 pm #25582
javier
ParticipantI am using wc vendors pro and what I want is to edit existing products, but the option disappeared with the last updates wcfm
- June 28, 2018 at 6:23 am #25592
OK, sorry. I assume wrong.
Well, WC Vendors also had 3 updates recently. Hope you have updated those as well, may be those updates causing something.
Anyway, kindly go to WCfM capability and be sure “Edit Live Products” option is ON.
Now, just press “Save” button once and it will refresh vendor users capabilities.
Please know me is this resolve the issue or not!
- June 29, 2018 at 3:49 am #25634
javier
ParticipantThis reply has been marked as private. - June 29, 2018 at 10:36 am #25641
Just relax, I am looking into this.
Thanks for the credentials.
- June 29, 2018 at 10:41 am #25642
This has been resolved, kindly take a look.
- The topic ‘Urgent: problem with the commercial manager’ is closed to new replies.
