Poila Boishakh
Celebrate Poila Baisakh with upto 20% OFF - A Fresh Start, A Great Deal!
02Day 00Hr 53Min 47Sec
Poila Boishakh
Urgent: Vendors unable to add or edit products
Best Multi Vendor Marketplace Plugin for WordPress Forums WC Vendors Urgent: Vendors unable to add or edit products
Viewing 5 reply threads
    • #37748
      jhweb
      Hi, I have had several vendors complaining that they can no longer add or edit products. I have tested it on a test account I have and I’m having the same issue. Basically everything works fine until you hit the Submit button. Then all you get is a spinning circle (see screenshot) This is the same issue when vendors attempt to edi their products. Please could you advise as soon as possible.
      Jon
    • #37756
      Bingal
      Do you recently updated any other plugins or theme?
      Kindly be sure there is no JS error in browser console.
      Also check at wp-admin -> WooCommerce -> Status -> Logs -> is any error there regarding this?
    • #37758
      jhweb
      Hi, thanks for your reply. I have checked the console and when I attempt to submit a product I get the following error on the console:
      HTTP403: FORBIDDEN – The server understood the request, but is refusing to fulfil it.
      (XHR)POST – https://mycrafty.co.uk/wp-admin/admin-ajax.php
      Then the page locks with the spinning circle.
    • #37793
      Opps! Do you have made any change in your server setup recently?
      Or, added any special permission using some plugin.
      Look – https://mycrafty.co.uk/wp-admin/admin-ajax.php
      This is a core WordPress file and responsible for all WP ajax request, now if this is not accessible then no AJAX request will work for the site.
      Between, are you getting the same issue as Admin as well?
    • #38756
      jhweb
      Issue resolved, it was a problem with the servers MOD Security.
    • #38840
      Great and thanks for updating me on this.
      Have a great day 🙂
  • The topic ‘Urgent: Vendors unable to add or edit products’ is closed to new replies.
