Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › use a Sidebar
- This topic has 8 replies, 2 voices, and was last updated 7 years, 11 months ago by
- January 12, 2018 at 7:29 am #17795
info17
ParticipantHi admins, new day new question:) sorry..
i like to use my own sidebar for like a help menu. its possible to show wcfm-main-content with my own sidebar. and if a user click inside the wcfm menu the sidebar shows up everytime? thank you and have a nice day. - January 12, 2018 at 8:54 am #17798
Good Morning 🙂
I am not very clear with your requirement.
Let me tell you what you can do with WCFM Menus –
1. Totally disable WCFM menu from WCFM Admin setting -> Dashboard
2. Add/edit/delete any WCFM menu items using some custom codeAre you looking to add a custom “Help Menu” item?
Feel free to reach us anytime for any assistance!
Simha - January 12, 2018 at 10:26 am #17799
info17
Participanthi again, i mean to put a normal standard sidebar on the left side from content..
wc ultimate as page content and an normal sidebar on the left.. (on my theme standard sidebar is on the left side)
if i try now to add your shortcode to a page with sidebar the standard sidebar not shoes up.. is there a way to show it..
i need no changes etc. in the wc ultimate menu.. just like to show up the standard sidebar check printscreen 🙂 (content is wc ultimate shortcode)
thank you - January 12, 2018 at 1:37 pm #17808
info17
Participantwired is when i make a normal page without your shortcode inside the sidebar display normal, when i put your shortcode inside the page is full width and no sidebar.. may you have a solution for this 🙂
- January 12, 2018 at 2:06 pm #17810
I understand your requirement.
Actually, WCFM uses its own template, it’s without sidebar. Full page width is preferable for Dashboard.
If you really want to disable this and want to use your theme template then kindly add this code to your theme/child theme’s functions.php
function wcfm_custom_dashboard_template( $page_template ) { global $WCFM; if ( wc_post_content_has_shortcode( 'wc_frontend_manager' ) && is_user_logged_in() ) { remove_action( 'page_template', array( $WCFM->frontend, 'wcfm_dashboard_template' ), 10 ); } return $page_template; } add_action( 'page_template', 'wcfm_custom_dashboard_template', 9 );Please know is this fulfill your requirement or not!
- January 12, 2018 at 2:17 pm #17811
info17
Participantoh men thank you so much :):)
- January 12, 2018 at 3:26 pm #17812
Welcome 🙂
Is this works for you perfectly?
- January 12, 2018 at 3:31 pm #17813
info17
Participantyep:)
- January 12, 2018 at 4:17 pm #17818
MemberGreat, thanks for confirming me this.
I am closing this thread for now.Feel free to reach us anytime.
Simha
- The topic ‘use a Sidebar’ is closed to new replies.
