Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Vacation mode enabled, still add to cart not disabling.
- This topic has 12 replies, 2 voices, and was last updated 6 years, 5 months ago by
wwsAdmin.
- April 20, 2019 at 10:24 am #58715
- April 21, 2019 at 6:18 am #58799
That’s strange! Actually, shop page and vendor’s store page is same.
Do you have any caching? Then clear once and check.
- April 21, 2019 at 7:55 am #58827
wwsAdmin
ParticipantCleared everything still the same
- April 24, 2019 at 6:29 am #59107
https://wclovers.com/wp-content/uploads/2019/04/image1.png – which store has “vacation” enabled ?
Which theme you are using?
- April 26, 2019 at 3:33 am #59490
wwsAdmin
ParticipantDear WCFM,
store: look what happened is on vacation, on product page and store page message is coming properly.
Theme : https://themeforest.net/item/rigid-responsive-woocommerce-theme/20421310Earlier it was working super fine.
thanks
- April 27, 2019 at 8:57 am #59639
– Don’t get your message!
- April 27, 2019 at 1:50 pm #59674
wwsAdmin
ParticipantHI,
Store name : look what happened;
This store is on Vacation,
ON product page of this store. Vacation message is coming and add to cart is disabled. Similar thing is happening on Vendor/store page.But under shop page or on home page where we show product via widgets , add to cart is enabled as you can see in image previously attached.
- April 27, 2019 at 5:00 pm #59700
– OK, understand. Possibly these are theme widgets and not WooCommerce standard.
Please know me which widgets you are using?
- April 27, 2019 at 7:32 pm #59715
wwsAdmin
ParticipantHI,
Some are woocom and some are theme based widget. earlier it used to work perfectly.
Can u look into theme https://themeforest.net/item/rigid-responsive-woocommerce-theme/20421310
thanks
- April 29, 2019 at 6:41 am #59822
MemberWe are checking this.
- April 29, 2019 at 7:00 pm #59987
wwsAdmin
ParticipantYeah Kindly.
- May 5, 2019 at 2:53 pm #60698
This has been resolved in WCFM Marketplace latest update, 3.0.5
Please update yours and take a look.
- May 7, 2019 at 5:57 pm #61083
wwsAdmin
- The topic ‘Vacation mode enabled, still add to cart not disabling.’ is closed to new replies.
