Various Adaptions
Viewing 2 reply threads
    • #29407
      teambot
      Are the following functions supported:
      – Disabling the inital “Store setup” after vendor registration?
      – Login via Social media (e.g. facebook)?
      – Showing the vendor name for each product?
      – Removing anything with has to do with money (i.e. no taxing, no shipping, no price tag)?
    • #29410
      d-n-13
      Can be done with a filter
      I don’t know
      Can be done from the settings
      You can disable most of them like taxing and shipping, I don’t know about the price, probably yes too.
      Wait for the support to answer you, their plugin can almost do everything.
      Best Regards,
    • #29480
      Thanks @d-n-13
      * Disabling the inital “Store setup” after vendor registration?
      – Add this to disable store setup add_filter( 'wcfm_is_allow_store_setup', '__return_false' );
      * Login via Social media (e.g. facebook)?
      – If you have social registration and user register using this and later become a vendor then they off course login using social media.
      * Showing the vendor name for each product?
      – It’s already there, but you may disable from WCFM Admin Setting -> Marketplace Setting
      * Removing anything with has to do with money (i.e. no taxing, no shipping, no price tag)?
      – Yeah definitely, from capability you may do this – https://ibb.co/g1Tghp
      But this capabilities comes with WCFM Ultimate
  • The topic ‘Various Adaptions’ is closed to new replies.
