Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › various bugs + improvements
- This topic has 17 replies, 3 voices, and was last updated 6 years, 8 months ago by
- December 22, 2018 at 1:00 am #40615
d-n-13
ParticipantHello wclovers
I’ve found few things that might be bugs.
1- Adding New Vendors in 2nd language (ar) will send email with (en) and link for (en) dashboard
2- Adding New Vendor will send email with username and password, when the new vendor tries to log in for the first time he gets access denied instead of store setup wizard : https://www.dropbox.com/s/0k84aj1rp10cnt0/add%20new%20vendor%2C%20access%20denied.jpg?dl=0
3- Adding New Vendor : vendor’s email should be automatically verified.
4- Adding option to choose all child categories : it is only needed for Sold In Country/City case. https://www.dropbox.com/s/8pdtcdd6g6r0ij4/Sold%20in%20countries%20cities.jpg?dl=0
5- Possibility to make some categories as radio ? not very important but preferred : https://www.dropbox.com/s/iekmt1y0bmx4bcm/possible%20to%20make%20some%20categories%20as%20radio.png?dl=0
6- Check boxes in RTL is not appearing currently : https://www.dropbox.com/s/quglha0hljuccmk/checkboxes%20in%20rtl.png?dl=0
7- Disable the ability for vendor to change store slug, I know there is a filter for it, can you provide it please ?
8- Very important feature, When adding new Vendor please add ability to choose membership at the same time (1 step), currently I need to add vendor and then I have to assign membership (2 steps)
9- Shipping By Country : Processing Time + Ships From. They don’t show up anywhere, not in single product page, not in invoice.
- December 22, 2018 at 2:14 am #40621
d-n-13
GuestThis reply has been marked as private. - December 24, 2018 at 7:35 am #40900
d-n-13
Participant“9- Shipping By Country : Processing Time + Ships From. They don’t show up anywhere, not in single product page, not in invoice.”
I would like to mention that I’m not able to make a contract with some companies because there is no estimated delivery period for the products.
- December 29, 2018 at 5:39 am #41600
– Will check2- Adding New Vendor will send email with username and password, when the new vendor tries to log in for the first time he gets access denied instead of store setup wizard : https://www.dropbox.com/s/0k84aj1rp10cnt0/add%20new%20vendor%2C%20access%20denied.jpg?dl=0
– Will check3- Adding New Vendor : vendor’s email should be automatically verified.
– Resolved in last update4- Adding option to choose all child categories : it is only needed for Sold In Country/City case. https://www.dropbox.com/s/8pdtcdd6g6r0ij4/Sold%20in%20countries%20cities.jpg?dl=0
– What does these means?5- Possibility to make some categories as radio ? not very important but preferred : https://www.dropbox.com/s/iekmt1y0bmx4bcm/possible%20to%20make%20some%20categories%20as%20radio.png?dl=0
– Just go to Capability and set limit “1” for such categories6- Check boxes in RTL is not appearing currently : https://www.dropbox.com/s/quglha0hljuccmk/checkboxes%20in%20rtl.png?dl=0
– Resolved in latest update7- Disable the ability for vendor to change store slug, I know there is a filter for it, can you provide it please ?
– Here it is –add_filter( 'wcfm_is_allow_store_name', '__return_false' );
– OK, will add9- Shipping By Country : Processing Time + Ships From. They don’t show up anywhere, not in single product page, not in invoice.
– Will show in checkout and invoiceThank You
- December 29, 2018 at 8:23 am #41606
I break your demo site 🙁
Can you please delete WCFM, WCFM Marketplace and WCFM Membership plugin using FTP?
And reinstall those.
2- Adding New Vendor will send email with username and password, when the new vendor tries to log in for the first time he gets access denied instead of store setup wizard :– These will be resolve for you.
- December 29, 2018 at 10:12 am #41629
d-n-13
ParticipantThe site is working now
- December 29, 2018 at 10:14 am #41631
MemberDo you installed “WCFM, WCFM Marketplace and WCFM Membership” these newly?
- December 29, 2018 at 10:14 am #41632
d-n-13
”I’m asking if it is possible to have an option to choose parent category and all its child categories with 1 button
- December 29, 2018 at 10:23 am #41635
d-n-13
ParticipantYes, new installation
I have copy from the Marketplace and Membership before deleting if you want them
- December 29, 2018 at 10:28 am #41636
d-n-13
Participant”
”Vendor can still chose more than 1
https://www.dropbox.com/s/s35kn2tvml8zi75/categories%20limit.JPG?dl=0
- December 29, 2018 at 10:36 am #41637
d-n-13
Participant”
”Currently (Processing Time + Ships From) doesn’t show, I just tried, you mean in next update ?
Also (Customer Support) Doesn’t show in invoice.
- December 29, 2018 at 9:07 pm #41696
d-n-13
Participant”
”Possible to make it show in Single Product Page just like Dokan ? so customer doesn’t have to add to cart then go to check out to know when to receive his product!
- January 5, 2019 at 12:53 pm #42328
– Those will be visible as Checkbox but not possible to choose more than 19- Shipping By Country : Processing Time + Ships From. They don’t show up anywhere, not in single product page, not in invoice.
– Will do thisThank You
- January 6, 2019 at 8:39 am #42445
d-n-13
Participant”
– Will do this
”Not all shipping modules have processing time + ships from, it needs to be added to all shipping modules.
My Temporary Solution : I’ve added Product Custom Field and made it show in single product page.
- January 8, 2019 at 6:32 am #42608
We have take care of this in latest update (2.0.7)
- January 8, 2019 at 10:51 am #42643
d-n-13
Thanks for the amazing support, I’m testing them now.
- January 8, 2019 at 10:52 am #42644
d-n-13
Participant”
– Will do this
”This option is not overriding the processing time : https://www.dropbox.com/s/itt6ulhgwqs2tzd/proccessing%20time.jpg?dl=0
Thank you.
- January 8, 2019 at 11:16 am #42654
MemberOK, checking this.
- The topic ‘various bugs + improvements’ is closed to new replies.
