Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Vendor Approval
- This topic has 7 replies, 2 voices, and was last updated 7 years, 3 months ago by
- September 19, 2018 at 3:00 pm #32008
- September 19, 2018 at 7:34 pm #32028
That’s something impossible.
Can you please know me your site’s registration link, I want try this once!
- September 19, 2018 at 8:14 pm #32034
mapmusic
ParticipantThis reply has been marked as private. - September 19, 2018 at 8:33 pm #32038
Thanks for the link, yeah it’s go to store setup (https://ibb.co/gO5NhK).
Well, can you please check one thing, WCFM Dashboard -> Setting -> Membership (At top bar) -> Approval (https://ibb.co/iCaYpz) -> Is this ON or OFF?
- September 19, 2018 at 8:36 pm #32039
MemberUmm … I think it’s some thing else, do you have created “Membership Plans”?
I think so, then check at “Basic Plan”, I think you have enabled “Approval” there. Set this OFF.
Or, you may unset “Basic Plan” from Membership general setting.Thank You
- September 19, 2018 at 8:37 pm #32040
- September 20, 2018 at 6:16 am #32092
mapmusic
Thanks for gudeline…there was unset Approval for Free membership, which is automatically set for new Vendor.
- September 20, 2018 at 4:16 pm #32136
MemberAhh … that’s the case, and I think Free Membership is set “Basic Membership” plan as well!
then just reset that.
- The topic ‘Vendor Approval’ is closed to new replies.
