Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Vendor Dashboard | Order
- This topic has 4 replies, 2 voices, and was last updated 6 years, 10 months ago by
wwsAdmin.
Viewing 4 reply threads
- September 23, 2018 at 6:27 pm #32325
- September 24, 2018 at 4:48 pm #32406
You have set commission mode “Admin” so it’s showing FEE for admin for the order.
If you set commission mode “Vendor” then it will show you Commission and 3.80rs
- September 25, 2018 at 4:35 pm #32527
wwsAdmin
ParticipantThis reply has been marked as private. - September 27, 2018 at 1:55 pm #32673
NO, “Unpaid” is showing that commission status, is this paid or not!
Off course this “paid/unpaid” relative to vendor.
“Because my membership says 5% which is admin commission.” – I have a easy suggestion for you, better set this vendor commission 95%, then things will more clear to you.
- September 28, 2018 at 3:43 am #32749
wwsAdmin
Ohh got your point.
- The topic ‘Vendor Dashboard | Order’ is closed to new replies.
