wcfm-santa
-365Day -2Hr -36Min -18Sec
wcfm-santa
Vendor dashboard -> Output text edit
Best Multi Vendor Marketplace Plugin for WordPress Forums WCFM – Ultimate Vendor dashboard -> Output text edit
Viewing 2 reply threads
    • #118232
      Jasmin Kronewetter
      Can you tell me in which one of the plugin files I can find the vendor dashboard? I’d just like to remove the ‘..!!!!’ in the output text of the ‘Sales by product’ section as well as change the wording in the inquiry section 🙂
      Thank you,
      Jasmin
    • #118234
      Jasmin Kronewetter
      For some reason I couldn’t submit my post when I had the attachment attached, so attaching it here 🙂
    • #118352
      You may use Loco Translate for text change.
      Here is a guide – https://localise.biz/wordpress/plugin/beginners
      example: Please select the plugin Loco Translate -> Plugins -> “WCFM – WooCommerce Frontend Manager” for changing the text
