Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Vendor Dashboard: Product Type Toolset Field Groups
Tagged: custom field groups, product manager tabs, toolset
- This topic has 10 replies, 2 voices, and was last updated 6 years, 6 months ago by
- February 15, 2019 at 11:03 pm #48464
Sean Mac
ParticipantHi!
FYI – Toolset released updates on their plugins today and I noticed the custom field groups no longer display in the product manager tabs.
- February 16, 2019 at 1:01 pm #48516
What is your Toolset plugin version?
- February 16, 2019 at 4:17 pm #48529
Sean Mac
ParticipantToolset Types 3.2.5
Toolset Views 2.7.3
Toolset Forms 2.3
Toolset Maps 1.7.2
Toolset WooCommerce Views 2.7.8 - February 16, 2019 at 4:26 pm #48530
We found the issue, will resolve in tomorrow’s update.
- February 16, 2019 at 4:55 pm #48538
Sean Mac
ParticipantThank you!
- February 17, 2019 at 1:52 pm #48596
We have just checked Toolset new version, it’s working fine.
But we noticed on big fault, after update previous field setting were lost. We have to create new filed groups –
Please check, are those there for you or not?
- February 17, 2019 at 6:17 pm #48622
Sean Mac
ParticipantAll of my field groups remained the same; I didn’t have to create any new field groups. However, I did notice there seems to be some conflict with Toolset Access 2.6.1.
As the marketplace admin, I can see the Toolset field groups in the product listing tabs but the vendors can’t see them. I removed all Toolset Access settings from my database and nothing changed. Then I deactivated the plugin and now the field groups are displaying for the vendors.
- February 18, 2019 at 6:53 am #48718
Do you had Toolset free and paid both installed?
If so, then it will not work. Keep only paid one.
- February 18, 2019 at 4:15 pm #48769
Sean Mac
ParticipantI am using only the paid version of all the Toolset plugins.
- February 19, 2019 at 6:39 pm #49054
Sean Mac
ParticipantToolset just released updated versions of Types and Access. Once I updated those plugins, the product manage tabs now display correctly.
Thanks for your assistance!
- February 20, 2019 at 4:50 am #49091
MemberGreat .. I also thought this, they had some bug in that update.
Otherwise, existing field groups can not be gone!Thanks for the update 🙂
- The topic ‘Vendor Dashboard: Product Type Toolset Field Groups’ is closed to new replies.
