Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Product HUB › Vendor name under products
- This topic has 22 replies, 4 voices, and was last updated 6 years, 9 months ago by
- September 20, 2018 at 1:55 pm #32123
Manoj
My website is not showing vendor name under products/product page and It’s because of my theme. Can you please help fixing it.
- September 21, 2018 at 7:30 am #32147
Kindly know me which multi-vendor plugin you are using?
And also you theme name please.
Just relax, we will help you in resolving this.
- September 21, 2018 at 1:47 pm #32163
Manoj
GuestThis reply has been marked as private.
- September 21, 2018 at 5:45 pm #32188
Manoj
GuestThis reply has been marked as private. - September 21, 2018 at 7:01 pm #32190
MemberHi Manoj,
Thanks for the details, we are looking into this and will update you soon.
- September 24, 2018 at 5:21 pm #32414
Manoj
Can you please update me If you are still fixing the issues.
- September 24, 2018 at 8:29 pm #32455
My team is checking that, I will update you soon, possibly by tomorrow morning.
Thanks for your patience.
- September 25, 2018 at 6:32 am #32481
Password not working for me.
Please know me correct one.
- September 25, 2018 at 3:38 pm #32523
Manoj
GuestThis reply has been marked as private. - September 26, 2018 at 9:06 am #32579
Thanks for the updated detaiLS, and it’s working for us.
We are checking this and will update you in few hours.
- September 26, 2018 at 9:38 am #32586
Sayan Naskar
We have included the vendor’s name in the single product page please check: http://buysellbooks.online/product/testing/
But as there was no child theme present in the site we have edited the parent theme file. /wp-content/themes/book-junky/woocommerce/content-single-product.phpAttachments:
You must be logged in to view attached files. - September 26, 2018 at 1:30 pm #32594
manojks148
ParticipantYou are awesome. Best Support.
I will try to add products and see if its working for all.
Thank you very much
- September 26, 2018 at 1:35 pm #32595
Sayan Naskar
Thank you for the appreciation. Please reach out if you need any more assistance. - September 26, 2018 at 2:10 pm #32596
manojks148
ParticipantThis reply has been marked as private. - September 26, 2018 at 3:24 pm #32598
manojks148
ParticipantThanks, I can see vendor name in single products.
Can you please help me with one last issue. Could it be possible to add Inquiry button under the store name you added in single product.
- September 27, 2018 at 11:59 am #32653
Sayan Naskar
We have added the Inquiry button in the single product page. But due to an error in the console from one of the plugins and total change in the default templates of woocommerce by the theme the default functionality of the inquiry button is not working. Please contact the plugin author for fixing the js error in the console so that we can implement the default functionality of the button compatible with the theme.Thank You
You must be logged in to view attached files. - September 28, 2018 at 1:42 pm #32792
Manoj
Can you please try now as I have disconnected the plugin that was causing problems.
- October 2, 2018 at 5:58 pm #33069
Manoj
GuestHey,
can you please update this request.
- October 3, 2018 at 4:01 am #33119
Member - October 3, 2018 at 1:39 pm #33196
Manoj
I just checked and its not working for me.
Please see console for JS errors.Thanks
- October 4, 2018 at 8:20 am #33249
Do you have backup-restore site files?
I have added a fix in WCFM which we will add in next update but it’s again reverted.
Anyway, I have again fix that – https://ibb.co/bQyMte
Please check now.
- October 4, 2018 at 1:45 pm #33273
Manoj
Thank you. I don’t have any backup of the website. I might try and backup now.
Thanks again.
- October 4, 2018 at 4:05 pm #33287
NO worries, update WCFM 5.1.3, now we have added this in WCFM core.
- The topic ‘Vendor name under products’ is closed to new replies.
