Vendor Page does not adhere to site template
Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Marketplace › Vendor Page does not adhere to site template
Viewing 9 reply threads
    • #118513
      wm
      https://byfarmers.market/lagrangetx/shop/fabulous
      I am just learning WCFM and setting up this store. It is not complete. I don’t understand why the vendor page follows a different template from every other page on the site (that I can tell). Why no sidebar widgets? Why no sidebar like the rest of the site? Also the vendor page is full width while the template is not. I have been reading in your forum and have so far been unable to find a solution. So far, I have been unable to change the vendor page width.
      I am using the Tempera template with a child theme.
      What I want is for the shop vendor page to conform to the template like all the other pages. The red menu bar is the correct width. See how much wider the vendor page is?
      Please help.
    • #118524
      wm
      And I just noticed that the footer is full width as well. the header is the correct width but the body and the footer are not.
    • #118553
      wm
      I am still testing and I see now that I have created a store list page using the short code [wcfm_stores] and that page also ignores the template for the website and is full width. It also ignores my sidebars. I can see the store list sidebar with all the WCFM widgets, but not MY sidebar with its widgets.
    • #118651
      We have tested Tempera theme(https://wordpress.org/themes/tempera/) with our WCFM plugins in our local server, and it’s working perfectly.
      Yes, we have noticed that “https://byfarmers.market/lagrangetx/stores” not working for you, please share us your site(https://byfarmers.market/lagrangetx) access details(Set as private reply), then we can check your site.
    • #118799
      wm
      It didn’t occur to me that it might be my child theme. I disabled the child and activated the parent, cleared the cache, and I don’t see a difference. Both on the vendor page (https://byfarmers.market/lagrangetx/stores) and the individual shop page (https://byfarmers.market/lagrangetx/shop/fabulous), the content is too wide and the sidebar appears after the content (this theme is responsive and that is the default on a “small” screen). I can see the toolbars for your plugin, but not mine. I don’t know if those are supposed to disappear with your pages or not (I prefer that my sidebars always appear) but at minimum, it is clear on my end that the sides of the page do not line up. I will post temporary credentials for an admin user in a minute.
    • #118801
      wm
    • #118803
      wm
      As you zoom in an out on either page, you can clearly see that WCFM content sticks to the side of the screen while my template remains fixed. Sorry, for so many comments, just trying to give you as much information as posssible. Thanks.
    • #119015
      We are unable to write the below style in your site, so please add this css code in your activated theme’s style.cs
      .wcfm-store-list-page #main,.wcfm-store-page #main {
          max-width: 1280px !important;
          margin: 0 auto !important;
      .wcfm-store-list-page #container.two-columns-left #primary {
          width: 220px !important;
          float: left !important;
    • #119092
      wm
      That definitely fixed it. Thank you very much. Now, the question becomes, is that a bug? I suppose this means that as I change the site settings, I will also need to continuously update this code snippet in order for those pages to conform. I tried moving the sidebar to the right (and adjusting your code accordingly) but it didn’t work. It would appear that I am stuck with limited layout options that are very similar to the one I currently have if I want it all to work. Clearly and I am not the kind of developer that can fix this on my own. Is it something that can be fixed in the next update maybe? Any thoughts? I am likely going to buy the ultimate package, but if I don’t, do you have a donation page? Thanks for the help.
    • #119429
      Ok, this is not a plugin’s bug. Our WCFM plugins are compatible with most of the themes available in market.(https://wclovers.com/wcfm-compatible-themes/).
      Though the theme “Tempera theme” you are using in your site is not compatible with style wise. However to fix the the style issue you can share us the page urls. We will guide you accordingly. Please be advise it will need development knowledge/effort.
      For more advance features we will always suggest you to upgrade to our premium WCFM-Ultimate plugin.
      If you wish to donate you can from here : https://wordpress.org/plugins/wc-frontend-manager/
      Thank You.
  • The topic ‘Vendor Page does not adhere to site template’ is closed to new replies.
