Multi Vendor Marketplace Plugin | WCFM Marketplace › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Vendor registration does not work
- This topic has 5 replies, 2 voices, and was last updated 6 years, 4 months ago by WCFM Forum.
- August 22, 2018 at 3:32 pm #29214TeambotGuest
The form for the vendor registration is showing as expected, but if I fill in the fields and click “register” the fields are cleared and nothing else happenes. No user was created and no error message was shown or whatever.
Any idea whats wrong? - August 22, 2018 at 4:11 pm #29219WCFM ForumMember
Thanks for reaching us here 🙂
Kindly share your site’s registration URL with me, I want to test the same.
- August 22, 2018 at 7:59 pm #29254TeambotGuest
- August 23, 2018 at 5:04 am #29288WCFM ForumMember
Thanks for the URL, but certainly it has no JS error.
Can you please check one thing, WCFM Admin Setting -> WCFM Pages -> Is this page set at “Vendor Registration” option or not?
I think it’s not set over there! Please set this and take a look.
- August 23, 2018 at 1:31 pm #29353teambotGuest
Thanks, that worked!!
Is it also possible to provide a page for customers to register? I do not want to use the standard woocommerce checkout page to create a customer.
Is it maybe possible to have one single used for the registration of customers and(!) vendors just using a checkbox to distinguish? Maybe re-using the above one? - August 24, 2018 at 4:58 pm #29547WCFM ForumMember
You may off course create separate registration for customers, you may use any WP login/registration plugin
But, WCFM Membership form specially made for only vendors, it can’t be used for customers or other users!
- The topic ‘Vendor registration does not work’ is closed to new replies.
