Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Feature Request › Vendor Registration Doesn't Work
- This topic has 1 reply, 2 voices, and was last updated 7 years, 10 months ago by
- August 12, 2018 at 3:07 pm #28381
james.gond
I have purchased WCFM Ultimate plugin integrated with WC Vendor Free version. Unfortunatelly, while I activated WCFM plugin, Vendor Registration setting in WC Vendor will automatically UNCHECK by itself, eventhough I have put check on Vendor Registration setting. I think Vendor Registration setting doesn’t work.
In order to test problem, I have tried to deactivate WCFM plugin. After that, I try to put check on Vendor Registration setting and fortunatelly, I get Vendor Registration setting works properly.
Could you like to fix this problem?
Thank you.
- August 13, 2018 at 11:01 am #28427
Thanks for get in touch with us and derailed description.
Actually, this is not because of WCFM or WCFM Ultimate.
You have also installed WCFM Membership (https://wordpress.org/plugins/wc-multivendor-membership/) and that disabled WC Vendors registration.
If you don’t want to use this then just delete this plugin and everything will be perfect.
- The topic ‘Vendor Registration Doesn't Work’ is closed to new replies.
