wcfm-santa
-363Day -14Hr -50Min -26Sec
wcfm-santa
Vendor registration fields
Viewing 7 reply threads
    • #19069
      kevin1
      Hi WCLovers,
      Is it possible to add a user password field on Vendor Registration Form. My client is wanting the user to set their password when signing up to become a vendor. This will simplify the process.
      Thank you.
    • #19070
      Can you please know me which registration form you are using for vendor registration purpose?
      If you are using WCFM – Membership then it already comes with “password” field at registration form.
    • #19073
      kevin1
    • #19077
      Thanks for your input, so you are using WC Product Vendors registration form.
      You can also manage this form fields, here is their official help guide for you – https://nicola.blog/2016/04/19/adding-custom-fields-vendor-registration-form/
    • #19078
      kevin1
      Thank you, I have seen her blog it only shows me how to add social profiles not set password fields.
    • #19079
      it’s a demo code. You may use this to add any fields in your form, don’t assume it’s only for social fields.
    • #19122
      kevin1
      I would just like to share.
      This plugin works perfectly adding in custom fields to registration area – https://en-au.wordpress.org/plugins/profile-builder/
      Styled nicely as well. Free version does pretty much what I need and paid version has some great extras for those who may need.
    • #19139
      Wow!! That’s awesome and thanks for sharing this with us.
      Pleasure 🙂
  • The topic ‘Vendor registration fields’ is closed to new replies.
