Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Vendor Shop | Title | Banner
- This topic has 18 replies, 4 voices, and was last updated 6 years, 10 months ago by
- October 3, 2018 at 5:21 pm #33211
- October 4, 2018 at 3:06 pm #33276
Really strange ones!!
Do you have set “Vendor Registration – Wonderwheel Store” this anywhere in Yoast setting?
Between, do you have set SEO setting for this vendor?
- October 4, 2018 at 6:48 pm #33301
- October 4, 2018 at 7:05 pm #33306
wwsAdmin
ParticipantHI,
NO SEO setting is done “do you have set SEO setting for this vendor?” this applicable to all the vendors.
2nd banner on shop is having title=”Forced to wrong size: 1902×244, natural is 500×500!” I don’t know how ? (IMG attached). only after login i can see this issue
You must be logged in to view attached files. - October 6, 2018 at 5:39 am #33387
DO you have any plugin for checking image size/alt/title ?
Yoast not adding this – https://ibb.co/iNz5rz
- October 6, 2018 at 6:48 am #33391
wwsAdmin
I have only https://wordpress.org/plugins/ewww-image-optimizer/
Something happens when we are logged in.
thanks
- October 6, 2018 at 9:49 am #33399
MemberNO, this plugin also has noting like that.
Can you please send me plugin list snap from your site?
- October 6, 2018 at 10:12 am #33402
- October 6, 2018 at 10:25 am #33407
OK, you have Yoast SEO Premium as well, I didn’t check with this.
Can you disable Yoast once and check, is this gone or not!
Between, thanks for the list.
- October 6, 2018 at 6:45 pm #33448
wwsAdmin
this is culprit https://wordpress.org/plugins/ewww-image-optimizer/. tried disabling and everything was normal.
- October 7, 2018 at 4:29 am #33470
MemberOpps! That’s really strange.
Is there any setting for disabling this?
- October 7, 2018 at 11:23 am #33489
- October 8, 2018 at 6:57 am #33524
MemberOK, thanks for this.
- October 11, 2018 at 2:09 pm #33814
james.gond
I just replace wc vendor to wcfm marketplace, also I have bought wcfm ultimate, wcfm staff manager, and wcfm statistic. But, according to wcfm marketplace, I got 2 inconvenience issues of logo, as follow:
1. I put square logo on vendor page, but I can not see cropped circle one. Square logo overlay above circular border field
2. Secondly, I put rectangle logo, I find oval shape on vendor name inside of product page.How can I fix it to meet the perfect layout?
You must be logged in to view attached files. - October 12, 2018 at 5:40 am #33835
Can you please share these two particular logos with us?
Or, give me those two store urls.I will test with them.
It requires some CSS fixing, I will give you that.
- October 12, 2018 at 6:43 am #33840
james.gond
ParticipantThis reply has been marked as private. - October 14, 2018 at 9:10 am #33970
Thanks for the details.
Kindly add this CSS to your site –
#wcfmmp-store .logo_area a img{border-radius:50%;}
- October 16, 2018 at 8:40 am #34098
Yulius Ari Budiyono
GuestHello,
I have a problem:
1. According to vendor favicon on product layout. The problem is while I want to set position favicon both vertical and horizontal direction. Could you help to solve problem? https://monosnap.com/file/QeDR7kyOpKQ0lNRFjxiI8naWPb0AjR#
(see red circle to new position I want)
2. According to ask question button, I can not edit css from existing smiliar to add to compare button with only border, and color hover while click the button. Can you help me, please! https://monosnap.com/file/dSkS0j8UpMjWJR7fxNMD3Afmm9wEtqThank you
- October 17, 2018 at 1:25 pm #34172
1. Kindly add this CSS –
.wcfmmp_sold_by_container_left img{margin-top: -10px;}
2. Please add this CSS –
a.wcfm_catalog_enquiry { background: transparent !important; border: 1px solid #fff!important; color: #111 !important; box-shadow: none; } a.wcfm_catalog_enquiry:hover { background: transparent !important; border: 1px solid #111 !important; }
- The topic ‘Vendor Shop | Title | Banner’ is closed to new replies.
