Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Vendor Store Design Question
- This topic has 1 reply, 2 voices, and was last updated 6 years, 6 months ago by
Sarmistha Chakraborty.
- April 16, 2020 at 3:57 am #119570
Jing Gu
ParticipantI have found your default vendor store design a lot more compelling than the vendor template of your Elementor Addon?
This is your Elementor addon default template. We added our comments on it in comparison to your default store template:
In contrast, this is your default vendor store template:
It is decent.
This can be found here: https://wcfmmp.wcfmdemos.com/store/demo-vendor
What can we do to switch back to your default?
Thanks a lot.
Jing
- April 16, 2020 at 3:01 pm #119711
Can you tell us which theme are you using?
https://wcfmmp.wcfmdemos.com/store/demo-vendor this “vendor store page” look is without using elementor. If you deactivate our “WCFM – WooCommerce Multivendor Marketplace – Elementor” you can find default “vendor-store page” layout without using elementor.
If you want to setup “Vendor Store ” page with elementor, then you have to do some style modification to get default layout look.Thanks.
- The topic ‘Vendor Store Design Question’ is closed to new replies.
