wcfm-santa
-365Day -3Hr -22Min -14Sec
wcfm-santa
Vendor Store: Number of products per page can\\\'t be set
Viewing 3 reply threads
    • #62288
      shitT
      Hello
      I try to set the number of products on the vendor page to 9 in the admin panel. It does not work (always 10). How can I fix this? BTW, I use the standard storefront theme.
      Thanks for your answer!
      Kind Regards,
      Gilbert
    • #62491
      – This will definitely work but for newly added vendors.
      For existing vendors it’s possible to change from vendor’s setting panel or from vendor manager -> store setting
      You may also add this to your child theme’s functions.php to make this fixed overall –
      add_filter( 'wcfmmp_store_ppp', function( $post_per_page ) {
      	$post_per_page = '9';
      	return $post_per_page;
      }, 50 );
    • #62556
      shitT
      Hi
      Great answer! Thanks a lot, problem solved:)
      Kind Regards
      Gilbert
    • #62776
      You are welcome :0
  • The topic ‘Vendor Store: Number of products per page can\\\'t be set’ is closed to new replies.
