Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Feature Request › Vendor Store page issues
Tagged: download picture, picture product, téléverser
- This topic has 13 replies, 4 voices, and was last updated 6 years, 5 months ago by
- March 5, 2019 at 7:00 pm #51228
digitalcinemacrew
ParticipantHi there,
I noticed 4 issues when I navigate in Vendor’s store pages:1) When I click on another page (2,3,4…) it doesn’t show me another page inside vendor’s store, but it redirects me to website Shop Page.
2) Below the footer are shown again vendor’s products.
3) When I switch language inside vendor’s store page, it redirects me to website Shop Page, instead of staying on same page.
4) Even if I set more products to be shown on Vendor’s Store page, it shows me always 8 products.
you can check all issues from here: https://www.digitalcinemacrew.com/store/antonioazzurrophotographygmail-com/
All my WCFM’s plugins are updated to the latest versions (WCFM, WCFMU, WC Multivendor Marketplace)
Please fix,
thanks!Attachments:
You must be logged in to view attached files. - March 6, 2019 at 8:00 am #51317
Which theme you are using?
Are you using “Elementor” or other some page builder for managing site templates?
Check at below of store page, there has something which loads default shop page here! Now, how this?
Can you please site caches once?
- March 6, 2019 at 1:23 pm #51372
digitalcinemacrew
I am using Storefront Theme and using Elementor Builder for custom post types only.
I have Toolset Types as well and after uninstalling Toolset Woocommerce Views, Shop Page below Store Page issue is solved. But I need Toolset Woocommerce Views. Any possibility to have WCFM and TS Woocommerce View compatibility?Anyway, other issues are not solved yet also after cacheing the site:
4) Even if I set more products to be shown on Vendor’s Store page, it shows me always 8 products.Any Idea?
- March 7, 2019 at 7:33 am #51472
Well, WCFM does not compatible with any such view plugins.
If you use with default Store front theme then there will be no such issues for Store page.
So, please kindly contact that plugin author to know, how store page can be exclude from there views?
Somehow, they can not recognize this page and corrupted it.Thank You
- March 7, 2019 at 9:18 am #51505
digitalcinemacrew
ParticipantOk, I’ll contact them.
And what about redirection issues?
I mean when I switch language and when I clink on page numbers…
And, why I always see 8 products per page even if I set 32?Thanks.
- March 7, 2019 at 11:44 am #51527
Which multi-lingual plugin you are using?
Well, where you have set per page product 32?
For store pages you may set this in places –
1. WCFM Admin Setting -> Marketplace Setting – Products per page
2. For existing vendors you have to tweak this from their own store setting panelThank You
- March 7, 2019 at 11:55 am #51528
digitalcinemacrew
ParticipantI’m using WPML plugin for multi-lingual
- March 7, 2019 at 12:08 pm #51532
MemberOK, we are checking this!
- March 7, 2019 at 1:27 pm #51545
digitalcinemacrew
ParticipantOk great!
- March 7, 2019 at 3:29 pm #51547
digitalcinemacrew
ParticipantAnd also try to understand why, when I click on page links (2,3,4…) in store page, it redirects me to shop page instead of stay on vendor’s store pages.
Thanks again.
- March 8, 2019 at 12:57 pm #51633
contact19
I have a serious issue.
1. IMPOSSIBLE TO ADD PICTURES ON PRODUCT FOR VENDOR: I have tested as vendor, to add product WITH PICTURES, by using my mobile.
Description to reproduce issue:
a) click on “téléverser” to download picture, and then choose a picture
b)validate your choice
c) result: there is no picture added on productIs wcfm non responsive?
My theme is “storefront”Many thanks for your help
- March 8, 2019 at 3:19 pm #51658
“result: there is no picture added on product”
*** Only images not updating? But other data are saved properly?
You do not have this issue from desktop? Image and other data properly saved from there?
- March 9, 2019 at 7:36 pm #51752
miguelsongramos
Participanthttps://dondemercado.com/tienda/danale/
how to make the store view page has the simimar design of main page? slider is not necesary, but the banner seems like is too big
- March 10, 2019 at 6:57 am #51813
Well, you may change banner height from WCFM Admin Setting -> Marketplace Setting -> https://ibb.co/Hxn4F5L
- The topic ‘Vendor Store page issues’ is closed to new replies.
