Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Vendor Store Settings Progress Bar Issue
- This topic has 5 replies, 2 voices, and was last updated 6 years, 10 months ago by
- October 3, 2018 at 6:14 pm #33222
WWW
Reporting an issue with the progress bar. The basic membership with minimal options enabled has only store tab and store policies tab enabled. All fields are filled in, but the progress bar shows that only a 44% of the progress is completed. Under the bar text suggests to add logo, banner, description etc, but those fields are not even enabled at this basic vendor level.
Disable the progress bar until this is fixed? - October 4, 2018 at 8:53 am #33253
Thanks for informing this to us.
We will definitely resolve this in next update.
Well, you may disable this progress bar by adding this code –
add_filter( 'wcfm_is_allow_profile_complete_bar', '__return_false' );
- October 4, 2018 at 2:57 pm #33275
WWW
ParticipantThanks. The snippet works fine. I disabled the bar until its fixed.
- October 4, 2018 at 3:10 pm #33277
WCFM and WCFM Marketplace new version just released.
Don’t disable anymore, please update and take a look 🙂
- October 4, 2018 at 3:57 pm #33284
- October 4, 2018 at 4:21 pm #33291
I think this percent is right!
What are setting options enabled there?
Just to mention, percent had no issues but suggestions are not right, we have just fixed that in 5.1.3
- The topic ‘Vendor Store Settings Progress Bar Issue’ is closed to new replies.
