Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Marketplace › Vendor store sidebar
- This topic has 7 replies, 3 voices, and was last updated 7 years, 5 months ago by
- December 25, 2018 at 10:45 am #41059
roxanapaulart
Participant1. I have a display issue with the vendor store sidebar. It doesn’t fit in.
2. I set up [wcfm_stores per_row=”3″ per_page=”10″] but only 2 fit in. If set up to 2, only one store fit in the space.page: https://www.collectionofcards.com/vendors/
and individual stores pages have the same issue
- December 25, 2018 at 4:25 pm #41099
Just checked.
Actually, your template width is too small.
DO you want to go with this?
If yes, then I will give you tweak CSS for this.
- December 25, 2018 at 10:56 pm #41127
roxanapaulart
ParticipantYes, thank you.
I would be grateful if you give me CSS to fix this.
All the best. - December 26, 2018 at 5:25 am #41146
Please add this CSS to your site –
#wcfmmp-stores-lists .left_sidebar, #wcfmmp-store .left_sidebar {padding: 2% 2px !important;} #wcfmmp-stores-lists .right_side, #wcfmmp-store .right_side{padding: 2% 2px !important;width: 73%;}And use this short code –
[wcfm_stores]
3 column view will not work in such small space.Thank You
- December 26, 2018 at 9:36 am #41179
Roxana Paul
GuestThank you, the sidebar now fits in.
The stores still cannot form 2 columns. Reducing the width in the CSS code above from 73% to 60% only moves the content to the right side. That creates a big margin on the left, but the second column is empty.
- December 26, 2018 at 10:20 am #41183
Do not change that CSS to 60%
add this css as well –
#wcfmmp-stores-wrap ul.wcfmmp-store-wrap li.coloum-2 { width: 45%; }Thank You
- December 26, 2018 at 10:39 am #41185
Roxana Paul
GuestGreat, thank you very much. Now it looks wonderful on the computer screen. Is there any way to align it on the mobile screen? Somehow it all falls to the right side.
- December 26, 2018 at 12:30 pm #41195
Please add this responsive CSS after previously added CSS –
@media (max-width: 767px) { #wcfmmp-stores-lists .right_side { width: 100%; } #wcfmmp-stores-wrap ul.wcfmmp-store-wrap li { width: 93% !important; } }Thank You
- The topic ‘Vendor store sidebar’ is closed to new replies.
