Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Vendors Product
- This topic has 5 replies, 2 voices, and was last updated 5 years, 8 months ago by
- December 10, 2019 at 9:51 am #96821
r_guayaquil
In a case a vendor wants to publish an offer for limited time only, can the product go to draft automatically after the offer expires so the clients wont see it?
- December 12, 2019 at 9:17 am #97161
You may use this plugin for the purpose – https://wordpress.org/plugins/woo-product-availability-scheduler/
- December 12, 2019 at 11:38 pm #97302
r_guayaquil
Thanks for the suggestion. The plugin you mentioned hasnt been updated for over a year and i was wondering if your plugin is compatbile with the one i found:
https://codecanyon.net/item/woocommerce-availability-scheduler/11649604
Thanks again! 🙂
- December 17, 2019 at 10:12 pm #97806
r_guayaquil
If I install the plugin I mentioned will also be available for vendors? There is no free version to try it, so first I want to be sure that the integración will work before buying it.
Thanks for the help! 🙂
- December 23, 2019 at 8:46 am #98589
r_guayaquil
ParticipantAny help??
- December 23, 2019 at 5:42 pm #98720
– Sorry, this is not yet compatible with WCFM. If you want to use this then please share this with us at wclovers.custom@gmail.com
We will make this compatible with WCFM.
- The topic ‘Vendors Product’ is closed to new replies.
