Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Marketplace › Vendors shipping Options
- This topic has 10 replies, 3 voices, and was last updated 6 years, 5 months ago by
Shakatime.
- November 2, 2019 at 1:24 am #90183
Shakatime
ParticipantHi.
Is there a plugin or a way to let the vendors create their own shipping prices?
- November 2, 2019 at 4:16 am #90210
Jamie O’Reilly
ParticipantYes there’s Per Product Shipping plugin but don’t go there yet as there are currently problems that need to be resolved.
- November 2, 2019 at 4:32 am #90216
Shakatime
ParticipantHi Jamie,
I just set up as per wight and test it it. I works fine, except that the product goes to Pending Approval but thee is no where to approve the product from the admin control panel.I had to go via WP admin.
- November 5, 2019 at 5:36 pm #90799
Sayan Naskar
Our plugin by default supports shipping by country, shipping by zone, shipping by weight.You can approve the product from the frontend itself. Screenshot attached.
You must be logged in to view attached files. - November 5, 2019 at 10:57 pm #90914
Shakatime
ParticipantHi Sayan,
This only works if they select to go to Draft, but not to a Send to Revision
- November 6, 2019 at 11:36 am #91031
Sayan Naskar
Please send a screenshot from where you are sending the product to revision status.
As if the vendor submits a product it is sent to Pending status, not revision status.
Thank You. - November 7, 2019 at 12:16 am #91187
- November 7, 2019 at 12:24 am #91190
Shakatime
ParticipantIs there a way to hide the button send to review?
- November 7, 2019 at 12:33 am #91191
Shakatime
may be you can help me with a shipping issue.
In the vendor settings, in the delivery or shipping, you can add a weight tables rules, ex.
up to 2 kilos = $3.50
up to 4 kilos = $5.50
up to 6 kilos = $7.50, etc., but when you press the save button, it will only save the last rule.If you go back and save the rule up to 2 kilos = $3.50, any products that has a shipping weight over 2 kilos will will show as a free shipping.
- November 7, 2019 at 12:48 pm #91265
Sayan Naskar
>>> If all you need all your vendors to submit the products to draft and not publish the products directly then use the CSS:#wcfm_products_simple_submit_button { display: none !important; }For the shipping issue.
I tested in my environment with the values you provided and the save functionality is working fine screenshot attached.
Maybe you are having some issues in javascript on your site.Please contact us here for the mentioning this issue and with your site access – https://wclovers.com/woocommerce-multivendor-customization/
Our team will look into the issue on your site and get back to you.Thank You.
You must be logged in to view attached files. - November 8, 2019 at 12:10 am #91343
Shakatime
I wrote already to multi vendors customization and I believe they are working on this issues.
Here is a link to a movie I did about the shipping: https://www.yazuz.com/videos/shipping-commission-issues.mp4
The other issue is with the commissions. I am charging 17% commission, and the payout to the vendors are wrong.
I am going to check the java scripts to see if this is causing the problem with saving the shipping rules.
Thank you for your help
- The topic ‘Vendors shipping Options’ is closed to new replies.
