Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Feature Request › Vendor's store layout
- This topic has 2 replies, 2 voices, and was last updated 6 years ago by
- August 14, 2019 at 4:09 pm #76628
Jamie O’Reilly
ParticipantHi. I’d like to move the accordion tabs (Description, Reviews, Policies etc) into a position on the left-hand side beneath the product image and thumbnail gallery. In effect this would put it in a left-hand column rather than it’s current position in a full template width area beneath all of the single product information – see screenshot. Please could you advise? Thanks
You must be logged in to view attached files. - August 14, 2019 at 4:55 pm #76640
Jamie O’Reilly
ParticipantOne more thing on this. We’ve tried adding the code to modify the standard Woocommerce output, but this doesn’t seem to work. Can you please check if these are the correct hooks to use:
// Move Product tabs underneath the product images
remove_action( ‘woocommerce_after_single_product_summary’, ‘woocommerce_output_product_data_tabs’, 10 );
add_action( ‘woocommerce_product_thumbnails’, ‘woocommerce_output_product_data_tabs’, 10 );
// =============================================================================Thanks
- August 20, 2019 at 6:56 am #77424
Well, this template is from theme, so please contact theme support for this.
