Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Vendors › Vendors store setting fields
- This topic has 6 replies, 3 voices, and was last updated 6 years, 1 month ago by
- May 14, 2019 at 3:36 pm #62209
productsexport
ParticipantSuddenly the vendor store setting fields are not in correct form. Also, logo image and banner image fields are missed up.
See screen shot. What can I do to fix this? Please help
You must be logged in to view attached files. - May 14, 2019 at 4:08 pm #62221
productsexport
ParticipantI am also seeing this in other screens like the WCFM Dashboard Setting
You must be logged in to view attached files. - May 16, 2019 at 1:59 pm #62486
DO you have deleted images manually from folder ?
- May 19, 2019 at 10:27 am #62898
productsexport
ParticipantI found the cause was “enabling Easy Loading” in the Flatsome Theme. When I unchecked that, the “vendor store setting fields” went back to normal.
- May 20, 2019 at 4:31 am #62972
OK.
enabling Easy Loading – this setting is problematic, we heard this before as well. Many things stop working after enabling this.
Just use normal caching and autoptimize. Your site will be super fast.
- May 30, 2019 at 6:27 pm #65028
Dima
GuestThis reply has been marked as private. - May 31, 2019 at 9:03 pm #65301
Off course vendors are able to all these from their setting panel – https://ibb.co/X7Wq6sY
- The topic ‘Vendors store setting fields’ is closed to new replies.
