Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Vendors › WC Vendors Pro
- This topic has 3 replies, 2 voices, and was last updated 6 years, 6 months ago by
- January 25, 2019 at 9:40 pm #45223
logandundon
ParticipantI just bought WCFM Ultimate and already have WC Vendors Pro installed and activated. There seems to be a conflict between the Woo Commerce Multivendor Marketplace and WC Vendors. Is Ultimate compatible with WC Vendors Pro? Or does it require you to use Multivendor Marketplace?
- January 26, 2019 at 2:46 am #45233
No, not at all. WCFM Ultimate has no conflict with any plugins.
Well, if you want to use WC Vendors, that’s fine.
Then just unistall “Woo Commerce Multivendor Marketplace” (It’s WCFM own multi-vendor module).
It’s not possible to keep 2 multi-vendor plugins at a time so that conflict message visible.
- January 26, 2019 at 9:07 pm #45368
logandundon
ParticipantThanks, but for some reason whenever I deactivate multivendor marketplace, I don’t get any of the wcfm ultimate features like refunds or chat. Is there a way to fix this?
- January 27, 2019 at 8:14 am #45399
Those features are from “WooCommerce Multivendor Marketplace”, so those will not work for WC Vendors.
You may check this – https://wclovers.com/blog/woocommerce-multivendor-marketplace-wcfm-marketplace/
- The topic ‘WC Vendors Pro’ is closed to new replies.
