Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › [wc_frontend_manager] doesn't load page properly (page load is all messed up)
- This topic has 8 replies, 5 voices, and was last updated 7 years, 1 month ago by
- May 16, 2019 at 2:29 pm #62498
LeSolist
ParticipantThis short code doesn’t appear to work properly. The page loads but it’s all messed up. Any idea?
Besides, the edit link on each and every product doesn’t trigger anything; it just reload the same page
There is no woocommerce error log, woocommerce status are all green. Any idea?Attachments:
You must be logged in to view attached files. - May 16, 2019 at 9:57 pm #62581
LeSolist
ParticipantYou may close this ticket. This is related to this issueProduct custom field module doesn’t appear
- May 17, 2019 at 3:55 pm #62667
Member- May 19, 2019 at 1:29 am #62894
LeSolist
GuestHi, that made the trick. Thank you. This happened when I enabled the “custom fields” module. For some reason, that reset the default page from “store manager” to something else.
- May 20, 2019 at 4:07 am #62966
MemberGlad to know it’s resolve for you.
But it should be reset by adding/editing custom fields!
Please know me, if you get the same issue again.
- August 20, 2019 at 8:14 pm #77563
ibrahimgunal
Participant[wc_frontend_manager] page is not displayed correctly.
You must be logged in to view attached files. - August 22, 2019 at 4:28 pm #77813
Please be sure this page is set at wp-admin -> WCFM Options.
- August 24, 2019 at 7:35 am #78104
Bernard Omolafe
ParticipantI am having this same issue with the page shrinking and none of the buttons working
jquery-migrate.min.js:2 JQMIGRATE: Migrate is installed, version 1.4.1
jquery.js:2 Mixed Content: The page at ‘https://spaceandtime.biz/store-manager/products-manage/’ was loaded over HTTPS, but requested an insecure image ‘http://spaceandtime.biz/wp-content/uploads/2019/06/WhatsApp-Image-2019-06-05-at-02.26.02.jpeg’. This content should also be served over HTTPS.
(anonymous) @ jquery.js:2
Arial.ttf:1 Failed to load resource: the server responded with a status of 404 (Not Found)
maps.google.com/maps-api-v3/api/js/38/1/intl/en_gb/util.js:240 Google Maps JavaScript API warning: NoApiKeys https://developers.google.com/maps/documentation/javascript/error-messages#no-api-keys
zx.i @ maps.google.com/maps-api-v3/api/js/38/1/intl/en_gb/util.js:240
maps.google.com/maps-api-v3/api/js/38/1/intl/en_gb/util.js:240 Google Maps JavaScript API warning: SensorNotRequired https://developers.google.com/maps/documentation/javascript/error-messages#sensor-not-required
(index):1 Failed to load resource: the server responded with a status of 500 (Internal Server Error)Attachments:
You must be logged in to view attached files. - August 29, 2019 at 12:30 pm #78947
You are checking only JavaScript error from browser console, but 500 error generate from PHP.
Please check at wp-admin -> WooCommerce -> Status -> Logs -> fatal_erros log -> what error generating?
- The topic ‘[wc_frontend_manager] doesn't load page properly (page load is all messed up)’ is closed to new replies.
