Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM › WCFM 4.1.4 icon lost
- This topic has 15 replies, 2 voices, and was last updated 7 years, 6 months ago by
- June 17, 2018 at 1:47 am #24944
nnapus
ParticipantThe icon in WCfM dashboard lost after update to V 4.1.4.
Thank you.
- June 17, 2018 at 2:09 am #24946
nnapus
ParticipantI think I’m having a problem with font awesome icons.
Regards.
- June 17, 2018 at 6:35 am #24958
Your site have this issue, font icon issue.
That star shows “S” is same type of issue.
Possibly there has some plugin which loads a very old version of font awesome and that breaks the things.
Can you check this from site’s page source?
- June 18, 2018 at 7:44 pm #25075
nnapus
ParticipantOk, I solved it already. Because of I try to update WCfM CSS font awesome to V.5, then make the icon on WCfM dashboard lost.
Thank you.
- June 19, 2018 at 6:41 am #25104
MemberAhhh … that’s not supported.
- June 19, 2018 at 9:04 am #25112
nnapus
ParticipantOMG! This issue does not about font awesome version updates.
I found that the WC Simple Auction plugin directly affects the WCfM dashboard icons.I just let you know, and I want to share.
May someone gives me an idea.My timeline;
1. Previous V 4.1.4.: My WCfM dashboard is normal.
2. The WCMp Team help me solve the “S” icon. It OK, the “S” icon gone and the star icon changes to the dark gray
3. Install WC Simple Auction.
4. Update WCfM/Ultimate to 4.1.4 – The main menu icon of WCFM lost.
5. Update the font awesome in WCFM/Asset/font Section to V.5. (to solve the dark gray icon: it does not the big problem, but I try.) – Nothing happens.
6. Delete WCFM/Asset/font Section V.5 and paste the old file of WCfM Asset/font V4.1.4 instead. – It’s Ok the WCfM main icon comes back only 30 minutes and then after lost again. – I don’t know what happened.
7. Deactivate WC Simple Auction. – That’s OK with everything. WCfM dashboard returns to normal.
8. I contact the WC Simple Auction supporter and wait for the reply.Now I found 2 problems with WC Simple Auction;
1. The plugin makes WCFM dashboard icon lost.
2. I have not the auction base page, and I try to create this page by putting the WC Simple Auction shortcode, but it does not work.
– The other process of WC auction is Ok.Do you have any idea?
Regards.
- June 19, 2018 at 9:50 am #25113
Can you please check WC Simple Auction Font Awesome library?
Is this too old ? Then update it and take a look.I have to Auction Page thing, not have that much of idea of this.
- June 20, 2018 at 10:18 am #25160
nnapus
ParticipantThis reply has been marked as private. - June 20, 2018 at 11:48 am #25163
This is not possible to change HTML using any code, and there has hundreds of these icons, it’s not a right solution.
I had checked with WC Simple Auction but there is no such icon issue due to this. Something else causing this, and CSS will be the only preferable solution for this.
Did you ever shared any access with me – Admin or Vendor? Then I will take a look at this.
- June 20, 2018 at 2:31 pm #25169
nnapus
ParticipantThis reply has been marked as private. - June 20, 2018 at 3:38 pm #25170
Thanks for the credentials, I am checking this.
Can you disable that minification plugin for the timing!
- June 20, 2018 at 3:48 pm #25171
nnapus
ParticipantDo you mean the Merge + Minify + Refresh plugin?
I will disable till you finished.
- June 20, 2018 at 4:00 pm #25173
MemberYeah that one.
- June 20, 2018 at 4:01 pm #25174
Kindly check the site, icons are there perfectly visible.
Merge + Minify + Refresh plugin causing something!
- June 20, 2018 at 4:17 pm #25176
nnapus
ParticipantThis reply has been marked as private. - June 20, 2018 at 4:22 pm #25178
Frankly, I have not much idea about this plugin.
Can you exclude Font awesome and take a try?
Be sure to refresh old minifies!
- The topic ‘WCFM 4.1.4 icon lost’ is closed to new replies.
