Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Feature Request › WCFM Activation issue
- This topic has 3 replies, 2 voices, and was last updated 7 years ago by
- July 25, 2018 at 2:56 pm #26905
digitalcinemacrew
I cannot activate WCFM ultimate plugin.
When I try to put provided API License Key and API License email, I got the messages “The license could not be deactivated. Use the License Deactivation tab to manually deactivate the license before activating a new license.” and “Connection failed to the License Key API server. Try again later.” and on WCLovers user dashboard it displays Activation 0 out of 1.
I’ve tried many times and in different days…Thanks!
You must be logged in to view attached files. - July 25, 2018 at 5:29 pm #26913
I think your server SSL is too old and our server not allowed this connect.
Can you please send me your WC status report?
Also know me your registered email address, i will re-test your license once.
- August 2, 2018 at 6:30 pm #27502
digitalcinemacrew
ParticipantHi, still having registration problems.
email address: digitalcinemacrew@gmail.com
WC status attachedThanks for your help!
You must be logged in to view attached files. - August 4, 2018 at 5:42 am #27566
So your site is over HTTP and not HTTPS, right?
Though I found that your “cURL Version” is too old, may be it’s causing the issue.
Between, I have checked your license and it is absolutely fine.
Can you please talk to your hosting provider once? may be some firewall setting blocking this!
- The topic ‘WCFM Activation issue’ is closed to new replies.
