Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Wcfm and woocommerce subscriptions
- This topic has 4 replies, 2 voices, and was last updated 5 years, 11 months ago by
kaloomee.
- August 9, 2019 at 9:37 am #75897
kaloomee
ParticipantTesting the integration of WCFM members and woocommerce subscriptions plugin
Can you lpease tell me how to attain the following :-
At present all vendors have access to the WC subscriptions plugin features
I would like that a vendor only has access to the WC subscription features if they have registered for a particular wcfm membership
ie
Plan 1 = access to wcfm multivendor store management only
plan 2 = has same as plan 1 but also access to WC subscription plugin features (Ability to create and manage their own memberships (WC Product))Will also need this for when I add the events plugin so
plan 3 = plan 2 features and events plugin featuresHope this makes sense
Regards
Kaloomee - August 12, 2019 at 9:03 am #76214
Well, membership wise different capability setting only possible using WCFM – Group (http://wclovers.com/product/woocommerce-frontend-manager-groups-staffs/) addon.
Are you using this?
- August 12, 2019 at 9:29 am #76222
kaloomee
ParticipantI am using Groups & staff’s bought it last week
- August 13, 2019 at 5:04 am #76344
Great, then please setup different capability for these two membership plans. https://youtu.be/pO4_9xEzWic
Allow subscription product type for one and OFF for another.
- August 13, 2019 at 9:21 am #76406
kaloomee
ParticipantExcellent, Thank you
Sorry you had provided solution video in reply to a different question I had butI negelected to reply to this thread
Different question but same solution
Thank you for your support
- The topic ‘Wcfm and woocommerce subscriptions’ is closed to new replies.
