Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Feature Request › WCFM compatibility with WooCommerce Product Add-ons issue
- This topic has 11 replies, 2 voices, and was last updated 6 years, 8 months ago by
- December 4, 2018 at 8:33 pm #39029
digitalcinemacrew
ParticipantDear Support,
since WooCommerce Product Add-ons went to version 3.0+ the tab “Add-ons” in WCFM doesn’t work properly with the WooCommerce extension:
The Add-ons types don’t match each other (see attached screenshots), so when you edit any product from front-end, something wrong happens to back-end in products editing page, and all products add-ons go not as expected in shop page – different layout, fields and so on…
Can you please fix compatibility between WCFM and new release of WooCommerce Product Add-ons? In previous versions it worked fine.
It would be perfect if WCFM Add-ons Tab and WooCommerce Product Add-ons will have the same fields to fill.Thanks!
You must be logged in to view attached files. - December 5, 2018 at 5:14 am #39047
Well, WCFM Ultimate already fully compatible with WC Product Addons 3.0+
Please be sure you have updated WCFM Ultimate 5.1.8+
Latest version is 5.2.0, better you update to this version.Thank You
- December 5, 2018 at 11:26 am #39084
digitalcinemacrew
ParticipantOk thanks, I’ll try it.
- December 5, 2018 at 7:36 pm #39104
digitalcinemacrew
ParticipantHi again.
I’ve installed 5.2.0 version. Now it works fine on new products, but I’m not able to edit old products from frontend.
I better explain my issues as Admin:1)I see Description and Short Description in HTML format (see attached screenshots)
2)All Meta Tabs are un-clickable, so I cannot modify anything on Vendor’s products (see attached screenshots)
3)No button is shown on the bottom of the page: “View, Draft, Submit…” (see attached screenshots)If I make new product as Admin all works fine.
Please help!
ThanksAttachments:
You must be logged in to view attached files. - December 5, 2018 at 9:31 pm #39117
digitalcinemacrew
ParticipantIssue update:
The problem is not on old products, but on published products, even with new ones. All is fine until the product is published, then I have the issue when I try to edit product from frontend as Admin - December 6, 2018 at 8:30 am #39144
From screenshot I found that there has some JavaScript error in your site.
Can you please check this in Google Chrome Browser console?
- December 6, 2018 at 10:43 am #39161
digitalcinemacrew
ParticipantHi, attached the screens of what i got from browser console.
It looks like a time format error.
One attached is from new product, the other one from already published product, from admin frontend dashboard.What can I do?
Thanks againAttachments:
You must be logged in to view attached files. - December 6, 2018 at 11:30 am #39171
Can you please share a demo vendor account with me to check this once?
Between, why your Admin’s editor look like this? – https://wclovers.com/wp-content/uploads/2018/12/admin-view-HTML-1.png
It should be like this -> https://ibb.co/4Y40vFjThank You
- December 6, 2018 at 12:54 pm #39199
digitalcinemacrew
ParticipantI’m trying to reply here with attachments, but I got error message…
- December 6, 2018 at 12:56 pm #39200
Member - December 6, 2018 at 1:02 pm #39202
digitalcinemacrew
ParticipantEmail sent, thanks!
- December 6, 2018 at 2:25 pm #39204
MemberReceived.
Closing this thread here.
- The topic ‘WCFM compatibility with WooCommerce Product Add-ons issue’ is closed to new replies.
