Black Friday
00Day 21Hr 12Min 06Sec
Black Friday
WCFM Dashboard – Vendor Shipping adjustments not saving
Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Marketplace › WCFM Dashboard – Vendor Shipping adjustments not saving
Viewing 18 reply threads
    • #21733
      ed
      I’m hoping you can help me with a problem I’m facing. I am building a marketplace website using WCMP + WCFM and setting up shipping zones in Brazil using Woocommerce Table Rate Shipping plugin along with WCMP advanced shipping.
      In Woocommerce I have had to create over 200 shipping zones as shipping in Brazil varies a lot. Each zone is set up with table rate shipping and sellers can adjust table rates in their seller dashboard. My problem occurs when I log into the dashboard as a seller and try to adjust the table shipping rates there. I have found that I can make adjustments for the first 110 zones but any adjustments to the remaining ~90 zones wont save properly and aren’t showing on the website when I go through the cart process.
      Do you have any idea why this could be happening?
      Thanks and Regards,
      Ed
    • #21779
      That’s something strange, if it does not save any of those than that will be a bug. But saving few is mysterious.
      Is you site live? Can you allow me to check the things once?
      Actually, it will be difficult for me to test the in my system as then I have to create 200 zones, quite time consuming. Hope you understand!
      • #21783
        Ed Stack
    • #21796
      Your site is live, now that’s a big concern.
      Is this possible to clone the site and setting up a staging for the site?
      Frankly, I have to debug the issue and it’s risky for a live site. Hope you understand.
      Please know me possibilities.
      Shhiv
    • #21908
      Ed Stack
    • #21923
      Ahh …fantastic.
      We are testing the things here.
    • #21936
      Ed Stack
    • #21939
      OK, thanks for the info.
    • #22143
      Our team is still debugging this.
      Please keep a bit patience.
      Between, is this possible for you to share FTP access for this staging site?
      Thanks for your cooperation.
    • #22201
      Ed Stack
    • #22206
      Thanks for the FTP details.
    • #22228
      We have tested the thing and found that issues is there.
      is this possible for you to increase two PHP parameters.
      Maximum size for post in PHP: Currently 65 MB, increase to 256 MB
      PHP maximum input variable (max input vars): Currently 1000, increase to 2500
    • #22248
      Ed Stack
      I have made those changes but not 100% sure if it’s done correctly.
      In order to change the max_post_size I created a php.ini file and added the new max_post_size value of 256MB there.
      I added the max_input_vars variable to the .htaccess file.
      Is that the correct way to go about it?
    • #22249
      NO, How you can create a php.ini?
      php.ini is already there in your server and you have to change these parameters there.
      It will be best for you to talk to hosting company how you can change this for your server?
    • #22402
      Ed Stack
    • #22420
      I am checking this again, just waiting for your server adjustment.
    • #22578
      Ed Stack
    • #22599
      Wow! That’s fantastic. What you change certainly and starts working. We were debugging but didn’t get any such clue!
      Well, WordPress does not support image edit option from front-end and wp-admin blocked for vendors, so media “Edit Image” option is not there.
    • #22602
      Ed Stack
      That’s great regarding shipping problem. I will go ahead and make those adjustments to the the live site also.
      For the ‘edit image’ capability. Is it possible with custom coding or no?
      Thanks and Regards
      Ed
    • #22630
      WordPress does not allow image editing from front-end at all.
      Still we will look into this if some alternate possibilities there!
  • The topic ‘WCFM Dashboard – Vendor Shipping adjustments not saving’ is closed to new replies.
