Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM › WCFM Geolocation: Show ALL Products
- This topic has 3 replies, 2 voices, and was last updated 6 years, 3 months ago by
gabriele.fortunato.
- May 12, 2020 at 11:19 pm #130183
gabriele.fortunato
ParticipantDear All,
I am using WCFM Geolocation and activated “Product List Radius Search” – Do you know if there is the possibility to setup in a way that Users are in any case allowed to see ALL products, no matter the radius ?In other terms, the user can activate or not the radius filter.
Thank you !
Kind regards
Gabriele - May 19, 2020 at 12:38 pm #132954
The radius search only works if the user provides an address, otherwise, it will always return all the products.
Thank You! - May 29, 2020 at 3:25 pm #136492
gabriele.fortunato
ParticipantThank you
is there a way for the User to RESET the radius filter after he entered an address and viewing all the products ?
To me it seems that the whole page Shop must be reloaded to remove the filter.
Please advice.
Thank you !
Gabriele - June 4, 2020 at 1:22 pm #138270
gabriele.fortunato
ParticipantGood morning,
would you please help with the RESET of the filter of radius geolocation ?
Thank you so much.
Gabriele
- The topic ‘WCFM Geolocation: Show ALL Products’ is closed to new replies.
