Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › WCFM Marketplace Conflict with Ultimate Membership Pro Registration.
- This topic has 3 replies, 2 voices, and was last updated 7 years, 7 months ago by
- September 3, 2018 at 12:29 pm #30658
Dan Eng
GuestHi Team,
I have purchased all of your plugins and was migrating from WC Marketplace to WCFM Marketplace.
However, I came across an issue where my vendors will be registering through Marketplace plugins while users will be managed by Ultimate Membership Pro.The Ultimate Membership Pro register page used to work, but once WCFM Marketplace been activated, the register will be blank.
Can you spend some time to look into this issue? I would think that some other users will have the same issue as I am having now.I would really want to use WCFM Marketplace instead of WC Marketplace.
Thanks for your support. - September 5, 2018 at 7:03 am #30835
Well, first of all it does not matter whether you are using WCFM Marketplace or WC Marketplace.
It’s only concern of vendor registration.
Is your “Ultimate Membership Pro” compatible with all these multi-vendor plugins and able to register vendors properly?
Please talk to this plugin’s author.WCFM own Membership module is there for the purpose – https://wordpress.org/plugins/wc-multivendor-membership/
It’s also there in your site and responsible for vendor’s normal registration, you may not use it’s membership options.Thank You
- September 5, 2018 at 9:33 am #30871
Dan eng
GuestThis reply has been marked as private. - September 5, 2018 at 9:42 am #30873
“Once I disable wcfm marketplace, the user register plugin (ultimate membership pro) works well” – are you also disable WCFM Membership at that time?
I think there has some configuration issues, as WCFM has no connection with “ultimate membership pro”, then how it’s conflicting.
Between, are you trying to same page for both registration or set in page setting?
I will definitely resolve this for you, but I don’t require any fee (thanks for the offer), please share your site access with me to check all this configurations – https://wclovers.com/contact-us/
- The topic ‘WCFM Marketplace Conflict with Ultimate Membership Pro Registration.’ is closed to new replies.
