WCFM Marketplace – Elementor integrated
  • This topic has 56 replies, 26 voices, and was last updated 5 years ago by MKL.
Viewing 47 reply threads
    • #81987
      tahitibora1
      I am not sure if this has been integrated yet?
      But i think it would be a major selling point for WC Lovers.
      Template designs for sellers/vendors shop pages and many other uses.
      Please please think about this
    • #82448
      We are going to a FREE addon for this very soon.
    • #82467
      tahitibora1
    • #82819
      Yeah right, we have already submitted this in wordpress.org and waiting for it’s released.
      mobile payment via sms for which country?
      Thanks for your patience 🙂
    • #84917
      t.banik
      So does it already work or not? Where can I find it? I have both Elementor and WCFM pro versions. Thanks
    • #85013
      Luke Lee
      Same question here, does this release yet?
    • #85039
      MarcusLee
      following !!!
    • #85264
    • #85423
      m.rejhan
      What does exactly this do? In system requirements says Elementor pro, I dont have pro version… Will there be any video tutorial soon
    • #85757
      Sajeesh Nair
      I tried this plugin and created a template. Things look good but the products connected to the store are not appearing. When I click the product tab, it says
      “No products were found matching your selection.”
      However, when I disable this template and revert to the default template, the product shows.
    • #85842
      MarcusLee
      Hi there, thanks a lot … not working for me right now.
      Display Conditions – please have it set to choose vendor as well !
      I wonder why there isnt a taxanomie like “BRAND PLUGINS” for Vendors anyway. It would help a lot – f.e. to display products for certain vendors only but there is no such way to trigger them !!!
      Cheers
      Marcus
    • #86467
      – Check this – https://youtu.be/0d-2wFlkg0I
      – Do you have product for that vendor?
    • #86994
      m.rejhan
      yt video is private can you make an update on that , thanks, and when i add elements in page they dont show…
      also can you in elementor separate wcfm elements from other wordpress ones in new dropdown tab for easier navigation
    • #87146
      Please check this video – https://youtu.be/0d-2wFlkg0I
    • #89477
      rockprince7
    • #89735
      mughalahmed786
      hello
      i contact priority support but no body reply us. How can i we contact wc lovers team ? we are interesting to buy paid plugins.
      thank you
    • #91015
      Template does not see category or any other widgets except search in sidebar.
      The inquiry button is still not showing ?
      – Well, you may add any WP widget undder store page sidebar using Elementor template edit.
      – Do you have any queries, you may know us here.
    • #91018
      rockprince7
    • #91056
      HOW DO YOU NOT UNDERSTAND MY ISSUE ? VENDOR CATEGORY IS PART OF WCFM STANDARD TEMPLATE. IT MUST SHOW ALL WCFM WIDGETS IN YOUR NEW ELEMENTOR INTEGRATED WIDGET TEMPLATE OR WHAT IS THE POINT OF THIS PLUGIN ??
      – We do not include all widgets under store template sample template. But you may insert any widget there.
      Should I show you video for this, how this can be done?
    • #97052
      raul.flores.arenas
      I´m using wcfm with elementor, yesterday elementor was actualiced, and now i can´t create the template for the store page in the elementor interface. I don´t know why this happened, please help us.
      I will attach the image of the error and we have the 5.3 WordPress Version.
      Thank you for the help,
      RaĂşl Flores.
    • #97241
      Please check this – https://youtu.be/0d-2wFlkg0I
      Be sure, you have created Store page template using Elementor.
      • #97349
        raul.flores.arenas
        I saw that video before, we do every step, and nothing, the error is still there, we delete and reinstall the complete wordpress project and the same.
        The error and our plugins are attatch in the first post, please help us.
        thank you for the help,
        Raul Flores.
    • #97653
      2A Network srls
      hello, I have a problem,
      I would like to include in their list of sellers of the shop their logo as per the photo I attach.
      How can I do? Every single retailer on the list of all sellers should have his logo next to his product.
      Thank you I await your kind reply.
      Antonio
    • #98311
      raul.flores.arenas
      can i edit the store list with elementor ?, i know i can edit the store page, but i want edit the store list too
    • #98643
      Sorry, store list not possible to edit using Elementor.
      But you may tweak it’s display using short code attributes. please check this for details – https://docs.wclovers.com/store-list/
    • #101902
      Cap Luis
    • #105845
      Cap Luis
    • #106030
      This has be resolved in WCFM Marketplace latest update, 3.3.1
    • #106113
      Cap Luis
    • #106412
      OK, you have created store template using Elementor.
      Elementor not yet support “video” and “slider” type banners.
      We will add this support in next update.
    • #109183
      how to display badges on the elementor editor?
      • #109876
        You may use this short code for the purpose- [wcfm_store_info data=”store_badges”]
    • #109547
      tahitibora1
      Please new feature: The ability and freedom to completely control, customize store list, and store pages with Elementor
      Add a WCFM/WCL Elementor widget or other?
      thanks
      • #109910
        Sorry, not get this clearly.
        • #109951
          Cap Luis
          Ability to create a store list page with elementor
    • #110286
      Matti
      It would be awesome if Elementor support would be added to articles pages. Currently those pages can be edited with rich editor. This would enable Store Vendors to create beautiful landing pages with Elementor and it’s templates library.
      Does anyone know how to add this with code snippet?
      • #110298
        Cap Luis
        I don’t know if this is a good thing, I wouldn’t trust Elementor to salespeople, it could be a mess.
        • #110304
          Matti
          Hi Cap,
          For my site it would be a fantastic feature and Vendors would love the feature.
          Elementor has role manager and to be honest current rich editor (TinyMCE) supported by WCFM is outdated. Even WordPress has moved to block editor for a long time ago. WCFM competitors have been adding Elementor support for a while. You just can’t keep up with competition with outdated editors.
    • #110297
      Matti
      I also appreciate if anyone knows how to replace tinyMCE rich editor with Gutenberg for articles pages (while waiting for Elementor support)
    • #110533
      memoryengravers
      Does anyone know of an Elementor add on that will display the limited time offers created by Vendors ? I’ve tried some, but nothing displays with the actual countdown clock.
    • #110626
      M M
      following this post
    • #112312
      gwin2003
      Hello
      Is this plugin compatible with Divi.If i use Divi will the store still work? Does this plugin also allow vendors to auction their products?
    • #114984
      Yes, WCFM well compatible with Divi Theme.
      For Auction feature you will require this plugin – https://codecanyon.net/item/woocommerce-simple-auctions-wordpress-auctions/6811382
    • #115012
      tahitibora1
      Hi guys,
      please please think about having an Elementor widget for all areas of wclovers front end manager etc…
      Having a widget for Elementor pro? so that we can customize store pages, layouts, maps, etc…
      WHY: Elementor has over 2, million users, so I think this would be a great potential new customer base for you and this would cut down requests from us all here.
      That equates to more potential customers!
      that’s possibly a lot of new customers!, you do the maths:)
    • #115283
      Well, it’s not possible to edit dashboard template using Elementor. in fact if you edit dashboard page template using Elementor it will generate error or you will get 404 error.
      Do you have edited “Store Manager” page template using Elementor?
      WCFM – Elementor (https://wordpress.org/plugins/wc-frontend-manager-elementor/) addon is already there to create custom store page template using Elementor.
    • #119310
      rytai
      Hello! My Vendor Registration and Membership pages stopped working. Just the shortcodes are still there. In the Setting – Dashboard pages – i don’t see any option to set neither Vendor nor the Registration pages. They must have dissappeared or smthn…Only the “Store manager” i see. how can i add them there?
      thanx.
    • #119961
      Kay
      Hello, you guys have not been replying to my priority emails.
      BTW, store carousel shortcode is not working with elementor, it works on page bakery.
      Please check and reply to my emails.
    • #120463
      thierry.jadot
      Hello, I have bought the Groups & staff this evening. That’s appears in my orders with status “completed”. When I check on my site’s dashboard >> marketplace >> capacity. It’s not OK so I am not sure if this has been integrated yet?
      nbr order is # 120455
      Could you check it
      Thank you,
      best regards,
      Thierry Jadot
    • #123210
      KadeO
      Hi I was just wondering if there was a shortcode available that works with the Elementor addon that can show the contents of the Vendors ‘Shop Description’ (wcfm_store_description). The ‘Store Tab Contents’ elementor widget does not quite do what we need to achieve.
      If there was also a way to call the Vendor Registration ‘Profile Additional Information’ Custom Registration Fields, that would be amazing.
      Cheers.
      • #137415
        MarsMars
        I agree it should be improved so we can redesign the content
    • #123463
      timvance00
      Hi, why is it that we pay a fortune for this package, yet we still have to pay for plugins, such as Elementor Pro to be able to complete a custom design. The current client side design looks very poor, and in this day and age where UI and UX is so important, why are we dealing with a design flow that looks to be 10 years old. Surely you can improve the design side of this package to bring it into the modern times.
      I have been using Divi theme builder for many years, only because Divi’s UI is far better than the Elementor packhage. Why can’t we use Divi to customer design all public pages of the WCFM multivendor package?
      I have included a couple of designs, one is a Divi designed template done in WooCommerce, the second is the WCFM layout, it is very ugly. It appears the elements controlling the layout are a global control, not very impressive at all.
      Surely there is an easier way to edit the layout than needing to add more plugins to the site that will only slow it down more than it already is.
      Since I have not been able to get a half decent response through the support, this place is the next best thing.
      When I first was asking about this system, I asked if Divi was supported, I was told it was, now I’m told it is not. I paid over $1100 AUD after being told this imformation, and now finding I was mislead.
    • #130868
      Nico Bein
      Is it possible to customize the product grid that is used for the vendor’s shop pages? I want to sell tickets and need to display the date, the location etc. in the grid…
      Best,
      Nico
    • #131318
      Keymaster
      Hi Nico,
      WCFM uses WooCommerce product loop to render products. So you can use WooCommerce hooks to add that information. May I ask which ticket selling plugin are you using?
      Let me know.
    • #134700
      MKL
      Is there any chance to test WCFM – WooCommerce Multivendor Marketplace – Elementor on your demo site?
    • #139709
      MKL
      No reply?
