Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › WCFM Marketplace – Elementor integrated
- This topic has 56 replies, 26 voices, and was last updated 5 years, 9 months ago by
MKL.
- September 16, 2019 at 8:09 pm #81987
tahitibora1
ParticipantI am not sure if this has been integrated yet?
But i think it would be a major selling point for WC Lovers.
Template designs for sellers/vendors shop pages and many other uses.
Please please think about this
- September 19, 2019 at 4:41 pm #82448
We are going to a FREE addon for this very soon.
- September 19, 2019 at 5:39 pm #82467
tahitibora1
ParticipantThis reply has been marked as private. - September 21, 2019 at 8:51 pm #82819
MemberYeah right, we have already submitted this in wordpress.org and waiting for it’s released.
mobile payment via sms for which country?
Thanks for your patience 🙂
- October 3, 2019 at 4:29 pm #84917
t.banik
ParticipantSo does it already work or not? Where can I find it? I have both Elementor and WCFM pro versions. Thanks
- October 4, 2019 at 3:03 am #85013
Luke Lee
ParticipantSame question here, does this release yet?
- October 4, 2019 at 10:41 am #85039
MarcusLee
Participantfollowing !!!
- October 5, 2019 at 1:24 pm #85264
MemberThis addon now available – https://wordpress.org/plugins/wc-frontend-manager-elementor/
- October 6, 2019 at 5:13 pm #85423
m.rejhan
ParticipantWhat does exactly this do? In system requirements says Elementor pro, I dont have pro version… Will there be any video tutorial soon
- October 9, 2019 at 6:28 am #85757
Sajeesh Nair
ParticipantI tried this plugin and created a template. Things look good but the products connected to the store are not appearing. When I click the product tab, it says
“No products were found matching your selection.”
However, when I disable this template and revert to the default template, the product shows.
- October 9, 2019 at 8:02 pm #85842
MarcusLee
ParticipantHi there, thanks a lot … not working for me right now.
Display Conditions – please have it set to choose vendor as well !
I wonder why there isnt a taxanomie like “BRAND PLUGINS” for Vendors anyway. It would help a lot – f.e. to display products for certain vendors only but there is no such way to trigger them !!!Cheers
Marcus - October 12, 2019 at 12:52 pm #86467
– Check this – https://youtu.be/0d-2wFlkg0I
– Do you have product for that vendor?
- October 15, 2019 at 8:28 pm #86994
m.rejhan
yt video is private can you make an update on that , thanks, and when i add elements in page they dont show…
also can you in elementor separate wcfm elements from other wordpress ones in new dropdown tab for easier navigation - October 16, 2019 at 3:29 pm #87146
Member - October 29, 2019 at 7:10 am #89477
rockprince7
ParticipantThis reply has been marked as private. - October 30, 2019 at 11:49 pm #89735
mughalahmed786
Participanthello
i contact priority support but no body reply us. How can i we contact wc lovers team ? we are interesting to buy paid plugins.
thank you - November 6, 2019 at 9:18 am #91015
Template does not see category or any other widgets except search in sidebar.
The inquiry button is still not showing ?– Well, you may add any WP widget undder store page sidebar using Elementor template edit.
– Do you have any queries, you may know us here.Thank You
- November 6, 2019 at 10:08 am #91018
rockprince7
ParticipantThis reply has been marked as private. - November 6, 2019 at 12:41 pm #91056
HOW DO YOU NOT UNDERSTAND MY ISSUE ? VENDOR CATEGORY IS PART OF WCFM STANDARD TEMPLATE. IT MUST SHOW ALL WCFM WIDGETS IN YOUR NEW ELEMENTOR INTEGRATED WIDGET TEMPLATE OR WHAT IS THE POINT OF THIS PLUGIN ??
– We do not include all widgets under store template sample template. But you may insert any widget there.
Should I show you video for this, how this can be done?
- December 11, 2019 at 8:57 pm #97052
raul.flores.arenas
I´m using wcfm with elementor, yesterday elementor was actualiced, and now i can´t create the template for the store page in the elementor interface. I don´t know why this happened, please help us.
I will attach the image of the error and we have the 5.3 WordPress Version.
Thank you for the help,
RaĂşl Flores.Attachments:
You must be logged in to view attached files. - December 12, 2019 at 5:27 pm #97241
Please check this – https://youtu.be/0d-2wFlkg0I
Be sure, you have created Store page template using Elementor.
- December 13, 2019 at 9:58 am #97349
raul.flores.arenas
I saw that video before, we do every step, and nothing, the error is still there, we delete and reinstall the complete wordpress project and the same.
The error and our plugins are attatch in the first post, please help us.
thank you for the help,
Raul Flores.
- December 16, 2019 at 9:34 pm #97653
2A Network srls
Participanthello, I have a problem,
I would like to include in their list of sellers of the shop their logo as per the photo I attach.
How can I do? Every single retailer on the list of all sellers should have his logo next to his product.
Thank you I await your kind reply.
AntonioAttachments:
You must be logged in to view attached files.- December 24, 2019 at 9:52 am #98864
MemberWell, by default store info visible with each product.
Is this any custom template?Between, which theme you are using for the site?
If will be best if you contact us here , we will resolve this for you – https://wclovers.com/woocommerce-multivendor-customization/
- December 21, 2019 at 10:08 am #98311
raul.flores.arenas
can i edit the store list with elementor ?, i know i can edit the store page, but i want edit the store list too
- December 23, 2019 at 11:11 am #98643
MemberSorry, store list not possible to edit using Elementor.
But you may tweak it’s display using short code attributes. please check this for details – https://docs.wclovers.com/store-list/
- January 13, 2020 at 7:23 pm #101902
Cap Luis
ParticipantThis reply has been marked as private. - February 6, 2020 at 4:58 pm #105845
Cap Luis
Participant?
- February 7, 2020 at 11:26 am #106030
MemberThis has be resolved in WCFM Marketplace latest update, 3.3.1
- February 7, 2020 at 6:18 pm #106113
Cap Luis
ParticipantThis reply has been marked as private. - February 10, 2020 at 2:19 pm #106412
MemberOK, you have created store template using Elementor.
Elementor not yet support “video” and “slider” type banners.
We will add this support in next update.
- February 28, 2020 at 3:29 pm #109183
pedagang.kakilima28
Participanthow to display badges on the elementor editor?
- March 4, 2020 at 1:58 pm #109876
MemberYou may use this short code for the purpose- [wcfm_store_info data=”store_badges”]
- March 2, 2020 at 3:42 pm #109547
tahitibora1
ParticipantPlease new feature: The ability and freedom to completely control, customize store list, and store pages with Elementor
Add a WCFM/WCL Elementor widget or other?
thanks
- March 4, 2020 at 2:45 pm #109910
MemberSorry, not get this clearly.
- March 6, 2020 at 5:22 pm #110286
Matti
It would be awesome if Elementor support would be added to articles pages. Currently those pages can be edited with rich editor. This would enable Store Vendors to create beautiful landing pages with Elementor and it’s templates library.
Does anyone know how to add this with code snippet?
- March 6, 2020 at 6:21 pm #110298
Cap Luis
ParticipantI don’t know if this is a good thing, I wouldn’t trust Elementor to salespeople, it could be a mess.
- March 6, 2020 at 7:25 pm #110304
Matti
ParticipantHi Cap,
For my site it would be a fantastic feature and Vendors would love the feature.Elementor has role manager and to be honest current rich editor (TinyMCE) supported by WCFM is outdated. Even WordPress has moved to block editor for a long time ago. WCFM competitors have been adding Elementor support for a while. You just can’t keep up with competition with outdated editors.
- March 6, 2020 at 6:01 pm #110297
Matti
ParticipantI also appreciate if anyone knows how to replace tinyMCE rich editor with Gutenberg for articles pages (while waiting for Elementor support)
- March 8, 2020 at 8:50 am #110533
memoryengravers
ParticipantDoes anyone know of an Elementor add on that will display the limited time offers created by Vendors ? I’ve tried some, but nothing displays with the actual countdown clock.
- March 9, 2020 at 12:59 am #110626
M M
Participantfollowing this post
- March 20, 2020 at 12:52 am #112312
gwin2003
ParticipantHello
Is this plugin compatible with Divi.If i use Divi will the store still work? Does this plugin also allow vendors to auction their products?
- April 3, 2020 at 9:50 am #114984
MemberYes, WCFM well compatible with Divi Theme.
For Auction feature you will require this plugin – https://codecanyon.net/item/woocommerce-simple-auctions-wordpress-auctions/6811382
- April 3, 2020 at 1:06 pm #115012
tahitibora1
ParticipantHi guys,
please please think about having an Elementor widget for all areas of wclovers front end manager etc…Having a widget for Elementor pro? so that we can customize store pages, layouts, maps, etc…
WHY: Elementor has over 2, million users, so I think this would be a great potential new customer base for you and this would cut down requests from us all here.
That equates to more potential customers!
that’s possibly a lot of new customers!, you do the maths:)
- April 4, 2020 at 1:40 pm #115283
Well, it’s not possible to edit dashboard template using Elementor. in fact if you edit dashboard page template using Elementor it will generate error or you will get 404 error.
Do you have edited “Store Manager” page template using Elementor?
WCFM – Elementor (https://wordpress.org/plugins/wc-frontend-manager-elementor/) addon is already there to create custom store page template using Elementor.
- April 15, 2020 at 2:06 pm #119310
rytai
ParticipantHello! My Vendor Registration and Membership pages stopped working. Just the shortcodes are still there. In the Setting – Dashboard pages – i don’t see any option to set neither Vendor nor the Registration pages. They must have dissappeared or smthn…Only the “Store manager” i see. how can i add them there?
thanx. - April 17, 2020 at 1:09 pm #119961
Kay
ParticipantHello, you guys have not been replying to my priority emails.
BTW, store carousel shortcode is not working with elementor, it works on page bakery.
Please check and reply to my emails.
- April 19, 2020 at 2:33 am #120463
thierry.jadot
ParticipantHello, I have bought the Groups & staff this evening. That’s appears in my orders with status “completed”. When I check on my site’s dashboard >> marketplace >> capacity. It’s not OK so I am not sure if this has been integrated yet?
nbr order is # 120455Could you check it
Thank you,
best regards,
Thierry Jadot
- May 8, 2020 at 10:44 pm #128533
You will need to download, install and activate those add-ons. Please follow this tutorial https://wclovers.com/blog/upgrade-wcfm-wcfm-ultimate/
Thank You!
- April 26, 2020 at 2:14 pm #123210
KadeO
ParticipantHi I was just wondering if there was a shortcode available that works with the Elementor addon that can show the contents of the Vendors ‘Shop Description’ (wcfm_store_description). The ‘Store Tab Contents’ elementor widget does not quite do what we need to achieve.
If there was also a way to call the Vendor Registration ‘Profile Additional Information’ Custom Registration Fields, that would be amazing.
Cheers.
- April 27, 2020 at 5:56 am #123463
timvance00
ParticipantHi, why is it that we pay a fortune for this package, yet we still have to pay for plugins, such as Elementor Pro to be able to complete a custom design. The current client side design looks very poor, and in this day and age where UI and UX is so important, why are we dealing with a design flow that looks to be 10 years old. Surely you can improve the design side of this package to bring it into the modern times.
I have been using Divi theme builder for many years, only because Divi’s UI is far better than the Elementor packhage. Why can’t we use Divi to customer design all public pages of the WCFM multivendor package?
I have included a couple of designs, one is a Divi designed template done in WooCommerce, the second is the WCFM layout, it is very ugly. It appears the elements controlling the layout are a global control, not very impressive at all.
Surely there is an easier way to edit the layout than needing to add more plugins to the site that will only slow it down more than it already is.
Since I have not been able to get a half decent response through the support, this place is the next best thing.
When I first was asking about this system, I asked if Divi was supported, I was told it was, now I’m told it is not. I paid over $1100 AUD after being told this imformation, and now finding I was mislead.Attachments:
You must be logged in to view attached files. - May 14, 2020 at 1:11 pm #130868
Nico Bein
ParticipantIs it possible to customize the product grid that is used for the vendor’s shop pages? I want to sell tickets and need to display the date, the location etc. in the grid…
Best,
Nico - May 15, 2020 at 3:17 pm #131318
KeymasterHi Nico,
WCFM uses WooCommerce product loop to render products. So you can use WooCommerce hooks to add that information. May I ask which ticket selling plugin are you using?
Let me know.
Thanks! - May 24, 2020 at 3:44 pm #134700
MKL
ParticipantIs there any chance to test WCFM – WooCommerce Multivendor Marketplace – Elementor on your demo site?
- June 8, 2020 at 10:45 pm #139709
MKL
ParticipantNo reply?
