Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Membership › WCFM membership option is not showing in store manager dashboard
- This topic has 32 replies, 15 voices, and was last updated 6 years, 4 months ago by
Sarmistha Chakraborty.
- April 19, 2020 at 2:10 pm #120572
Well, Membership module by default comes with disable mode. If you want to Vendor Membership then enable this module and setup vendor membership plans.
Please go to WCFM Admin Setting -> Modules -> Enable “Membership” module – https://ibb.co/6F9rmQ7
- April 20, 2020 at 6:35 pm #120993
Kristina Hillyard
ParticipantI have some vendors that dont know how to set up a store. Do i need a password for complete control over setting up there store? How do i do this without requiring that i have their password
- April 20, 2020 at 7:41 pm #121039
Please create knowledge-base for vendor where you guide them.
https://wclovers.com/knowledgebase/wcfm-knowledgebase/Thanks.
- April 21, 2020 at 11:59 pm #121497
trawler-captain
ParticipantHey Good morning, i have exactly the same problem. just installed it fresh today on a new wordpress version and no update or submit button. even the comments and settings i made in the wizard are not in the system. so for now i cant use it at all.
- April 22, 2020 at 1:36 pm #121681
Sorry, can’t get your issue. Can you explain little more?
is WCFM membership option not showing in your store manager dashboard? (you have written your issue “WCFM membership option is not showing in store manager dashboard” in this topic).Thanks.
- April 22, 2020 at 3:57 pm #121749
thierry.jadot
ParticipantThis reply has been marked as private.- April 22, 2020 at 7:14 pm #121862
Do you installed & activate our “WCFM – Groups & Staffs” plugin in your site?
You have only shared username of you site MyFactory.shop. Please provide us password as well so we can login your site and check your site.Thanks.
- April 23, 2020 at 10:40 pm #122278
trawler-captain
Participantsorry my mistake it is the wrong thread. i have problems with the update settings button or save settings button in the backend. it is nowehere. i will open a new topic. in the correct area.
- April 24, 2020 at 2:20 pm #122482
Do you mean update/save not working in WordPress dashboard->Settings?
Thank You.
- April 24, 2020 at 2:30 pm #122484
Philip Sheehan
ParticipantHi, I am having the same problem. I have downloaded the plugin and activated it but the membership option is not showing up in my wc dashboard so can not set it up.
- April 24, 2020 at 6:39 pm #122553
You have WCFM marketplace and WCFM-membership plugins activated?
Please check once you have turn-on the “Membership” module from WCFM dashboard -> Settings -> Modules (PFA)Thanks.
- April 25, 2020 at 2:27 am #122726
arellanovictor21
ParticipantHi, attached is a bug message that Im having in the commission tab of the membership module.
You must be logged in to view attached files.- April 25, 2020 at 12:17 pm #122824
Please update WooCommerce and our WCFM plugins.
- April 26, 2020 at 8:49 am #123139
pallavpriyank
ParticipantHello I want to hide seller information from my website. Its already disabled on website when browsed on desktop. But its visible on mobile APP. Bellow sizes -Their is a panel of Seller Information – View Store= Complete details of seller. How To Hide seller information in mobile app.As I have already un ticked from settings marketpalce. And how can I add additional css if needed from Appearance-Customizes-when trying to add msg is “Markup is not allowed in CSS.” Non technical kindly elaborate
You must be logged in to view attached files. - April 27, 2020 at 2:02 pm #123610
Sayan Naskar
MemberHello @pallavpriyank
You have given a screenshot of the website where the customers can see the products where they can buy the products. There, not showing the vendors is okay.
But the wcfm mobile app – store manager app is designed for the vendors. So only vendors can log in to the app. How can vendors only login and not able to see themselves? So it is not possible for the mobile app. - April 27, 2020 at 6:17 pm #123708
pallavpriyank
ParticipantNo this is not WCFM vendors APP. It is actually Ciyashop Mobile APP for the customers. Which they download from Play Store.https://codecanyon.net/category/mobile?term=ciyashop&gclid=Cj0KCQjwhZr1BRCLARIsALjRVQPU1hS8frlsoJOdOxE35KFyToc-nI66s60pahdw2CyjUBCO9PzVY8gaAid6EALw_wcB
- April 27, 2020 at 10:28 pm #123823
Sayan Naskar
MemberHello @pallavpriyank,
Fo the third party mobile app you must contact the app developer of that particular app and get your app customized from them - May 4, 2020 at 8:50 pm #126587
directorweb
Participanthola tengo el problema de la membresia pero con productos, no me deja crear productos de membresia que debo hacer, ya active el complmemnto
- May 4, 2020 at 9:19 pm #126599
You can find here – https://wclovers.com/wcfm-compatible-plugins/ list of plugins which are supported with our WCFM plugins.
>>For which plugin you are looking for this “membership support”?Thanks.
- May 7, 2020 at 7:14 pm #128062
thierry.jadot
I’m not very glad about your products and services. I bought a staff&groups plugin but I never receive the plugin (where can I download it).
2de problem, for one month, I have developed a marketplace – so, I have bought your WCFM – WooCommerce Frontend Manager, download the WooCommerce MultiVendor Marketplace and the WCFM Membership. That’s working 3 weeks. Sinds a week, nothing working correctly. That begins by a uncompleted dasboard (a vendor dasboard and not a admin dashboard). I have tried to disable, cancel and reinstall the plugins 3 times. A bugg append. It’s appears that the cancelling isn’t perfect – the data s aren’t erased. Happily, it’s only the development phase.I’m sure that is easily resolvable. Could you:
1. send the plugin staff&groups
2. help me to clean the data of my internet site and resend a compatible WooCommerce Frontend Manager, version WooCommerce MultiVendor and WCFM Membership version.When my problems will be resolved, I will think working, and buy more by your company.
best regards,
Thierry Jadot
Belgium- May 7, 2020 at 7:58 pm #128067
Firstly we have asked you for password 22nd April. You have only send us the username of your site.
>>Let us know your order number( Set as private reply)2. help me to clean the data of my internet site and resend a compatible WooCommerce Frontend Manager, version WooCommerce MultiVendor and WCFM Membership version.
>>Which things are not working correctly ? In between if you have added any custom code then at first remove those code.And Kindly disable all other plugins except WooCommerce and WCFM plugins. And then check.
We need your site access(username and password), so we check check your site.Thanks.
- May 23, 2020 at 10:16 pm #134540
whybuysell
ParticipantHi, I have bought WCfM Ultimate and Groups and Staffs Add-on. And i have successfully installed and Activated both on my website.
I have also Activated free WooCommerce Multivendor Membership plugin.
Problem I’m facing is I’m not able to see ‘Simple Subscription’ Product type in Product Types as shown in your YouTube Video.
I have attached Screenshot in this message. Please check.
You must be logged in to view attached files. - May 25, 2020 at 2:55 pm #134994
Member - May 28, 2020 at 3:07 am #135997
jmccoy.info
Can you explain to me what exactly does Vendor Membership do pls? Is this a replacement for 3rd party plugins such as Woocommerce membership plugin?
Thanks – Justin
- May 29, 2020 at 11:25 am #136427
It is our WCFM Addon plugin(https://wordpress.org/plugins/wc-multivendor-membership/).
Please check for more details – https://wclovers.com/forums/topic/wcfm-membership-option-is-not-showing-in-store-manager-dashboard/#post-135997
https://www.youtube.com/watch?v=SfOMIxNfr3w
https://www.youtube.com/watch?v=3JuFD35BiWIThanks.
- June 1, 2020 at 1:37 pm #137244
graficodomenico
Participanthi i have a problem i can’t translate the text. admin fee :.
This text is found when an email for the order summary for a seller arrives. I use Loco translation but I was unable to find this string. Where can I find this word in the translation code?THANKS
- June 1, 2020 at 2:13 pm #137247
You will find the text Loco translate -> Plugins -> WCFM – WooCommerce Frontend Manager -> select language -> search the string “admin fee” (https://docs.wclovers.com/locotranslate-translation-using-loco-translate-plugin/
It will not work with the existing old order, it will work with new order details.Please for different issues create a different thread or post the issue in the respective thread.
- June 13, 2020 at 5:59 pm #141109
Stephen Ackon
ParticipantHOW TO MEMBERSHIP PLAN AS RECOMMENDED?
- June 15, 2020 at 10:28 pm #141493
Sorry, We did not get your query. Please explain a little more.
For membership documentation check here – https://wclovers.com/knowledgebase/wcfm-membership/Thanks.
- June 15, 2020 at 3:05 pm #141426
justboloindia
Which codecanyon / evato market template support your plugin? We want seller location radios search and multi vendor supported app, who work same way as web site.
Please guide us.- June 15, 2020 at 10:26 pm #141492
Please check for supported codecanyon theme- https://wclovers.com/demos/
https://wclovers.com/wcfm-compatible-themes/Thanks.
- June 16, 2020 at 6:46 am #141582
justboloindia
Thanks for your reply. We are not searching for theme. We are searching for app which show user nearby stores only.
We have tired lots of scripts. None is supporting this .
That’s why we are looking for suggestions. - June 18, 2020 at 10:49 pm #142340
Sorry, but we don’t have this kind of App.
- The topic ‘WCFM membership option is not showing in store manager dashboard’ is closed to new replies.
