WCFM Multiple Errors & Issues
Viewing 0 reply threads
    • #138525
      pranav.i.m.here
      I need help with following:
      1. Remove/disable tags from product page
      2. Remove/disable Virtual & Downloadable product check box
      3. Remove seo, facebook and twitter etc from vendor setup widget and anywhere else as well
      4. Remove/disable product description – just want to keep the short description option
      I tried doing 1, 2 & 3 after reading about various queries from users. So it worked – but after that when a product is being added from vendor account. It shows error. Screenshot is attached for error being shown.
      Point 4, I simply want to disable product description box.
      Theme: Flatsome
      Plugin Used to insert all codes is: Code Snippets
      Declaration: I am free tier user of WCFM plugin.
      Can someone please help
  • The topic ‘WCFM Multiple Errors & Issues’ is closed to new replies.
