Multi Vendor Marketplace Plugin | WCFM Marketplace › Forums › WCFM › WCFM settings problem
- This topic has 4 replies, 3 voices, and was last updated 5 years ago by
Ramamurthy Krishnan.
- January 28, 2020 at 5:33 am #104320
egocheaga93
Participanthi,
I’m having problems to get in settings form. I can get it all the tabs but not there. Just appear a 500 server problem.
Internal Server Error
The server encountered an internal error or misconfiguration and was unable to complete your request.Please contact the server administrator at webmaster to inform them of the time this error occurred, and the actions you performed just before this error.
More information about this error may be available in the server error log.
Additionally, a 500 Internal Server Error error was encountered while trying to use an ErrorDocument to handle the request.
“”””””””””””” - January 28, 2020 at 12:30 pm #104364
Ramamurthy Krishnan
Have you customized anything or used any custom code snippet? If yes then it may be responsible for causing this issue.
- February 6, 2020 at 1:26 pm #105718
MemberPlease check at wp-admin -> WooCommerce -> Status -> Logs -> fatal_erros log -> is any error generated?
- February 10, 2020 at 11:19 pm #106553
egocheaga93
I didn’t customize anything or use any custom code.
I have this in “wp-admin -> WooCommerce -> Status -> Logs”:
geolocation-2020-01-16-0311ee02aafc61d53cb75f53fcf73993.log
wcfm-2020-01-20-b3e2f99f0821d71a9eb3dd2706676024.log - February 17, 2020 at 12:10 pm #107430
Ramamurthy Krishnan
Can you please check whether you are sending us the latest error log report or not?
If yes then please share your website login details with us, we will check.Please share your website login credentials as private reply here.
