Poila Boishakh
Celebrate Poila Baisakh with upto 20% OFF - A Fresh Start, A Great Deal!
00Day 10Hr 05Min 45Sec
Poila Boishakh
WCFM Stores on Homepage
Viewing 16 reply threads
    • #116537
      office-6501
      Hello all. I use this shortcode – [wcfm_stores per_row=”4″ per_page=”20″] on the homepage to display the vendors. Unfortunately when I scroll down, the map hides the sticky header. I use Flatsome theme. Someone has a solution for this?
      Simon
    • #116774
      We tested our local server using Flatsome theme.(PFA) And it’s fine.
      Can you share us the page URL, then we can check it and guide you accordingly.
    • #116791
      office-6501
      https://onlinehofladen.1010dev.eu
      Don’t wonder if there is nothing else on the site. Currently we are just testing!
      • #116792
        Try the css n your activated theme’s style.css
        .wcfmmp-stores-listing .wcfmmp-store-list-map {
            z-index: 1;
    • #116795
      office-6501
      Hey,
      thanks for the very fast reply. I tried that but it’s still not working.
    • #116831
      Please paste the css rght way. now it was (PFA)
      Â Â z-index:1
      It will be,
          z-index: 1;
    • #116920
      office-6501
      Thanks for the help it is working now!
      BR Simon
    • #117197
      frederiklamote
      I am testing WCFM with the Divi theme and got a little issue on the homepage.
      This is the code that is displaying on the front end as regular text when the homepage is loaded
      [vc_row][vc_column][vc_basic_grid post_type=”post” max_items=”10″ grid_id=”vc_gid:1553977993083-c7a20a2b-4dee-7″][/vc_column][/vc_row]
      Other pages are working, only the homepage seems to have this issue
      • #117575
        Can you please confirm when you activate our WCFM plugins(with DIVI theme) then your home page will broken?
    • #118448
      grafix2b
      Hello, i use WCFM with the Store Front theme,
      WCFM widgets are invisible when they are activated …
      I can’t use the stores lists …
      Please Help
      regards
      • #118482
        Our WCFM plugin is tested with “Store Front” theme and it’s works perfectly.
        It seems like there is some conflict with some other plugin in your site. It will be better if you provide us the admin access of your site, then we can check your site.
    • #118452
      grafix2b
    • #118503
      grafix2b
      Hello
      here the ids
      login
      Dev
      Pass
      Devmerkatoo@
      thanks
      • #118507
        grafix2b
    • #118510
      grafix2b
    • #118689
      grafix2b
      Hello Sarmistha, thanks you so much ! 🙂
      I want to hide the country filter on the sidebar with country=”” but the filter is still here :/
      can you help me please ?
      ( the stores widgets on homepage are still invisible)
      regards
      • #118719
        To remove “country” filter, Add this code in your activated theme’s functions.php,
        add_filter('wcfmmp_is_allow_store_list_country_filter','__return_false');
        >>Sorry, it will not work for home page. The “Store widgets” are for only “Store list” page.
    • #118732
      grafix2b
      Thanks you very much !
    • #118747
      grafix2b
      I tried to access the store list page to change the map zoom, but I got a 500 error.
      I have disabled all plugins except woocommerce and your plugin.
      It seems to come from your plugin, when I activate it, I can no longer modify the pages :/
      What can i do please ?
      • #118789
        We have checked in your site, by only activating WooCommerce and our WCFM plugin, we are able to edit pages. (PFA)
        It seems like there is some conflict with other plugin when activated.
    • #118989
      grafix2b
      Thanks you !
    • #120358
      grafix2b
      Hello, is there a way to have a pick up agenda for sellers? For example, if a seller offers a collection time for an order, the buyer can choose this time slot to collect his order.
      Regards
    • #120369
      Please create another thread for different issues/requirement.
