Diwali
02Day 17Hr 02Min 11Sec
Diwali
WCFM Ultimate – ACF Integration – Conditional Rules (inside same group)
Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Feature Request › WCFM Ultimate – ACF Integration – Conditional Rules (inside same group)
Viewing 3 reply threads
    • #27924
      rap
      Two little things I think would help to improve WCFM:
      1) It would be great if you could integrate ACF’s conditional rules of the fields inside the same group during product creation.
      Example:
      Group Field: Material
      Field 1: Material
      – Metal
      – Wood
      Field 2 Metal Type(appears if Metal selected)
      – Aluminum
      – Zinc
      Field 3 Wood Type(appears if Wood selected)
      2) Display ACF fields in Product summery/description.(I found a couple functions around for this, but didn’t work)
      Not in a hurry for this, but definitely would improve my vendors experience.
      Thanks for your time.
    • #27926
      Sure, we implement this very soon. We will add support of ACF Repeater field as well.
      I am moving this thread into Feature Request section.
    • #30748
      fabeluna
      Conditional logic for custom fields in relation to product category would also be very nice.
      Example 1:
      Category: Fashion
      Custom field: Size: S/M/L/XL
      Example 2:
      Category: Food
      Custom field: features: vegan/raw/bio/paleo/fairtrade
      Are you planning to integrate this feature, too?
      Leonie
    • #30848
      WCFM already compatible with ACF this feature.
      Please setup your fields and take a look.
  • The topic ‘WCFM Ultimate – ACF Integration – Conditional Rules (inside same group)’ is closed to new replies.
