Black Friday
01Day 23Hr 56Min 24Sec
Black Friday
WCFM Vendor page
Viewing 8 reply threads
    • #128218
      Eden Brownlee
      Btw is there anyway I can change how the product is being displayed? And if I can add a new tab in the frontend… We do have a products that are physical and services, I want them to be separated in the tabs.. The product will have the grid layout and the services will be in list format, is this possible?
    • #128315
      >>Basically, in vendor store page product tab will display same as WooCommerce Shop page template. Whatever customize shop product display in shop page, it will reflect in your vendor’s store page.
      >>Can you let us know how you differentiate between physical product and services product n your site?
      You can find here how to add new tab – https://wordpress.org/support/topic/custom-tab-in-vendor-store-page/
    • #129365
      Eden Brownlee
      I have a category for physical and services products 🙂
    • #129366
      Eden Brownlee
      And Btw how do I change the order of tabs in the vendor store? Ty
    • #129367
      Eden Brownlee
      I am getting a 404 after adding a new tab… I have re-saved permalinks already.
      add_filter( ‘query_vars’, function( $vars ) {
      $vars[] = ‘services’;
      return $vars;
      }, 50 );
      add_filter( ‘wcfmmp_store_tabs’, function( $store_tabs, $store_id ) {
      $store_tabs[‘services’] = ‘Services’;
      return $store_tabs;
      }, 50, 2 );
      add_filter( ‘wcfmp_store_tabs_url’, function( $store_tab_url, $tab ) {
      if( $tab == ‘services’ ) {
      $store_tab_url .= ‘services’;
      return $store_tab_url;
      }, 50, 2 );
      add_filter( ‘wcfmp_store_default_query_vars’, function( $query_var ) {
      global $WCFM, $WCFMmp;
      if ( get_query_var( ‘services’ ) ) {
      $query_var = ‘services’;
      return $query_var;
      }, 50 );
      add_filter( ‘wcfmmp_store_default_template’, function( $template, $tab ) {
      $template = ‘store/wcfmmp-view-store-services.php’;
      return $template;
      }, 50, 2);
    • #129368
      Eden Brownlee
      Ohh all good now 🙂 How do I change the order of tabs? 🙂
    • #129375
      Eden Brownlee
      One last thing 🙂 The tabs seems to have no active class when clicked. hehehe
      So to wrap things up, adding a custom tab is now working.. but the tab do not have active class when it is the current page.
      And how do I filter that the shop will only show physical products via filtering.
    • #129513
      You can re-order your tab –
      add_filter( 'wcfmmp_store_tabs', 'new_wcfmmp_store_tabs_1105',150,2);
      function new_wcfmmp_store_tabs_1105($store_tabs, $id) {
          $new_store_tabs = array();
          $keyOrder = ['about','products','reviews', 'policies','followers']; //reorder your tabs
          foreach($keyOrder as $key) {
              $new_store_tabs[$key] = $store_tabs[$key];
          return array_filter($new_store_tabs);
      Using this code.
      The active tab have “active” class in the wrapper “li”.
      >> You have to add “STORE CATEGORIES” widget in vendor store sidebar side
      Ref: https://wordpress.org/support/topic/show-only-specific-categories-in-vendor-store-page/
    • #129950
      Eden Brownlee
      That worked! TY 🙂
  • The topic ‘WCFM Vendor page’ is closed to new replies.
