WCFM vendor store page url translation issue with WPML
Best Multi Vendor Marketplace Plugin for WordPress Forums WCFM – Feature Request WCFM vendor store page url translation issue with WPML
Viewing 7 reply threads
    • #40399
      digitalcinemacrew
      Hi again,
      I’m using WCFM Marketplace and WCFM Ultimate. My website (https://www.digitalcinemacrew.com) has 2 languages (EN=primary – IT=secondary) using WPML.
      On EN version, Vendors Stores pages work properly (ex. https://www.digitalcinemacrew.com/store/argentio/), but when I switch to 2nd language it gives me error on page, because it provides wrong URL to the translation (ex. https://www.digitalcinemacrew.com/store/?lang=it/argentio/). You see “/?lang=it” is not at the end of the URL, but after “/store”. And same for other endpoints of vendors store page (ex. https://www.digitalcinemacrew.com/store/?lang=it/argentio/reviews/). If I manually put it at the end of URL (https://www.digitalcinemacrew.com/store/argentio/reviews/?lang=it) the page shows 2nd language properly. WPML is working fine for all the website pages but this.
      Is it a WCFM or WPML issue?
      Thanks a lot!
    • #40451
      Your WPML setup is not right.
      Please remember to set the URL structure to site.com/lang.
      It does not support URL parameters. So you can NOT set the URL structure to be site.com?lang=it
      Hope you understand my point.
    • #40455
      digitalcinemacrew
      so no way to make it work with /?lang=it parameter? modifing the url structure to /lang give me a lot of page errors and it will brake my seo indexing…
    • #40463
      NO, this will not work.
      Not even Store page, WCFM Dashboard will not work with such WPML setup.
    • #40466
      digitalcinemacrew
      Ah ok.
      Dashboard is working fine with /?lang=it parameter by the way…. I’ll try to set /lang structure on WPML then.
      Thanks again!
    • #40470
      Dashboard will work but dashboard endpoints will not work properly.
      Specially, you will not able add translated product from dashboard.
    • #40740
      digitalcinemacrew
      I changed URL structure to /lang/ directory and now it is working properly.
      Thanks for your help!
    • #40743
      Great … thanks for updating me.
      Have a great weekend 🙂
  • The topic ‘WCFM vendor store page url translation issue with WPML’ is closed to new replies.
