WCFM Vietnamese language problem
Best Multi Vendor Marketplace Plugin for WordPress Forums WC Marketplace WCFM Vietnamese language problem
Viewing 4 reply threads
    • #116210
      ambassador.tuan
      Dear Support Team
      I use Poedit for translate Pot file of WCFM to Vietnamese, and I upload to wp-content/languages/plugins already.
      But when I choose Vietnamese on my website nothing change.
      Please help me,
      Thank you very much
    • #116265
      You may use Loco Translate for translation.
      Here is a guide – https://wc-marketplace.com/knowledgebase/wcmp-translation-guide/
    • #116503
      ambassador.tuan
      Dear Support Team
      Thank you for your reply. But after I translated the WCFM plugin (Frontend Manager; Multivendor Marketplace; Multivendor Membership) I need to send the PO, and MO to you through the email: contact@wc-marketplace.com for My language version or not ?
      Best wishes
    • #117711
      ambassador.tuan
      Dear Support Team
      I done the translate of 3 plugin WC FRONTEND MANAGER; WC MULTIVENDOR MARKETPLACE; WC MULTIVENDOR MEMBERSHIP
      But the translation just load some text, other text like my attached file that can not change.
      Please help me if you know how
      Thank you very much
      P/s: I also try use load_plugin_textdomain with code below:
      function wc_frontend_manager_load_textdomain() {
      load_plugin_textdomain( ‘wc_frontend_manager’, false, dirname( plugin_basename( __FILE__ ) ) . ‘/languages/loco/plugin/’ );
      add_action(‘plugins_loaded’, ‘wc_frontend_manager_load_textdomain’);
    • #118367
      We have tested in our local server, the “Membership” text is translated properly. Kindly follow the steps, select the plugin Loco Translate -> Plugins -> “WCFM – WooCommerce Multivendor Membership” -> select your language -> translate the string(PFA)
      For changing the WCFM Store manager menu text, change the menu label from WCFM Storemanager dashboard -> settings -> menu manager. (PFA)
