Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › WCFM – WooCommerce Multivendor Marketplace – 3.4.0 Update Issues
Tagged: shortcode, store list, store map, WCFM Marketplace
- This topic has 1 reply, 2 voices, and was last updated 5 years, 3 months ago by
tgl.
- May 15, 2020 at 6:20 am #131169
KadeO
ParticipantI just updated to version 3.4.0 of the marketplace plugin and there were a number of updates related to the maps and the the Store List – amongst many others, which is awesome thank you 😀
3.4.0
*Updated – 13/05/2020Enhance – Store List search by “City” and “Zipcode” option added – Documentation
Enhance – Store and Product location using map url improved to show exact location on Google map with marker
Enhance – Store setup responsive and RTL CSS improved
Tweak – Map default pin icon changed
Fixed – Product archive radius filter “no match” condition showing all stores on map issue resolved
Fixed – Map default location and default zoom not working for all maps issue resolved
Fixed – Store and product list map “auto_zoom” not working properly issue resolvedHowever we are now having issues with the shortcodes for the store list and map not working properly, the map which we hid has now reappeared
We use the shortcode [wcfm_stores theme=’compact’ per_row=”2″ orderby=’newness_desc’ map=””] (and now the store list layout breaks if we remove theme=’compact’ from the code)
On a separate map page we had [wcfm_stores_map map_zoom=”12″ country=””] and now the country/location filter has re-appeared since the new update.
(we have also tried map=” and map=”no”, cleared caches etc…)
We tried following the info here… https://docs.wclovers.com/store-list/ but it appears some of the shortcode options are not listed there.
We also have an issue with the Store List Map having the pin in the wrong location (as the image for the pin looks at the LAT and LONG for the location, but the image has the top left pixel at the marker point not centred – See attached (the marker should be on same spot as the blue ATS Google pin)
Any help you can provide with fixing these couple of things up would be greatly appreciated. 😀
You must be logged in to view attached files. - May 27, 2020 at 4:53 am #135580
tgl
Participant@KadeO there are a few of if trying to figure out the issue with the map markers, you are welcome to join our discussions, we set up an unofficial FB group: https://www.facebook.com/groups/users.of.wcfm.marketplace/
