Multi Vendor Marketplace Plugin | WCFM Marketplace › Forums › WCFM – Ultimate › WCFM Woocommerce Products
- This topic has 6 replies, 3 voices, and was last updated 6 years, 7 months ago by
- July 21, 2018 at 4:48 pm #26685
info31
ParticipantHi there,
I’ve added a WooCommerce event product into my store.
How can I get the “EVENT” option to show up on my WCFM Front End Form when I add a new product?
https://cl.ly/t9EGThis is what I currently get:
https://cl.ly/t9EGI’ve tried to adjust the CAPABILITIES on WCFM, but it doesn’t show the option to add in the “EVENT” under a Simple Product.
- July 22, 2018 at 8:02 am #26712
Are you getting this as Admin?
Which plugin you are using for the purpose?
- July 22, 2018 at 2:52 pm #26754
info31
ParticipantYes. I am getting this as an ADMIN account.
I am using a Woocommerce plugin for Tickets called FOOEVENTS.
How can I make that show up in the front end, so my vendors can fill up the details for the tickets?
- July 24, 2018 at 7:22 am #26855
By default WCfM only works with WooCommerce Box Office (https://woocommerce.com/products/woocommerce-box-office/) as Event plugin.
You may use other but that will be a custom integration.
- July 24, 2018 at 4:15 pm #26880
info31
GuestThank you.
What is the process for custom integration?
WooCommerce Box Office didn’t fit my needs so I ended up with FooEvents plugin.
All i need now is for a way to show the events options on the WCFM Front End. Would you help guide or advise, please?
Thank you.
- July 25, 2018 at 3:08 pm #26908
info31
GuestHi there.
Any updates on how I can get additional WooCommerce settings to show up on WCFM?
- July 26, 2018 at 3:25 pm #26964
You may override WCfM product manager template under your child theme for adding additional fields.
And use this hook for save those fields – do_action( ‘after_wcfm_products_manage_meta_save’, $new_product_id, $wcfm_products_manage_form_data );
- The topic ‘WCFM Woocommerce Products’ is closed to new replies.
