Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › wcfm_stores and wcfm_stores_map shortcodes not showing the stores on the map
- This topic has 3 replies, 2 voices, and was last updated 6 years, 4 months ago by
- December 18, 2018 at 7:30 am #40291
Roque
GuestDear Friends,
I’m testing your software, and I’m having a problem with the above mentioned shortcodes. For example, when using the wcfm_stores shortcode, a map is shown, and below the map a list with some of my stores (which is correct). But the markers corresponding to the stores are not painted in the map, and the map is centered somewhere else (our stores are in Germany, the map is centered in Egypt).
Our google maps api key is correct and working. Our stores have a correct address. What are we doing wrong?
Thanks in advance,
R. Campos.
- December 19, 2018 at 7:38 am #40349
“Our google maps api key is correct and working. Our stores have a correct address. What are we doing wrong?”
– Well, do you have setup store’s location using map from vendor’s setting panel?Thank You
- December 19, 2018 at 7:58 am #40356
Roque
thank you for the advice. yes I was doing it wrong. I was searching for this option in the superadmin view, until I realized that I have to login myself as the vender to find it.
Thank you for your help.
Regards.
- December 19, 2018 at 8:18 am #40365
“I was searching for this option in the superadmin view,”
– You can off course do this from Admin login as well.
GO to WCFM Admin Dashboard -> Vendors -> Vendor Manager -> Store Setting (https://ibb.co/n7C2cWr)Well, be sure you are using WCFM Marketplace (2.0.2) and WCFM (5.2.5) latest versions.
- The topic ‘wcfm_stores and wcfm_stores_map shortcodes not showing the stores on the map’ is closed to new replies.
