WCFM Anniversary
We've turned 8! Celebrate with us and take away upto 25% OFF on WCFM Addons.
03Day 01Hr 26Min 47Sec
WCFM Anniversary
What is the hook
Viewing 5 reply threads
    • #110054
      MarsMars
      Hi
      I want to activate an action one a vendor select a product to be added to his/her store
      So what is the hook for add to my store
      Regardd
    • #110068
      You can use this action do_action( 'after_wcfmmp_product_multivendor_clone', $duplicate->get_id(), $product );
      You can check this php file <wc-multivendor-marketplace>/core/class-wcfmmp-product-multivendor.php
      function name: wcfmmp_product_multivendor_clone
    • #110075
      MarsMars
      thanks..
      but seems its not working.. or I am doing something wrong
      do_action( 'after_wcfmmp_product_multivendor_clone','doSomeThing' );
      function doSomeThing()
        alert("I am an alert box!");
    • #110079
      Please go through the function “wcfmmp_product_multivendor_clone”. The action “after_wcfmmp_product_multivendor_clone” is a php code which we provide you.
      If you want add some javascript, then add below script in your “js” file –
      jQuery(document).ready(function ($) {
      	$('.wcfm_product_multivendor').click(function(event) {
    • #110144
      MarsMars
      thanks for help
      this is wasnt the error
      the error was I should use add_action not do_action
    • #110218
      You have to write,
      add_action( 'after_wcfmmp_product_multivendor_clone','doSomeThing',10 ,2 );
      function doSomeThing($duplicate_id, $product)
        //add your php code here
      Ref: https://developer.wordpress.org/reference/functions/do_action/
  • The topic ‘What is the hook’ is closed to new replies.
